Cog dyno/boost results.........
big bos, i don't think it's slipping, could just be breaking in dust fromthe belt, or even dust from the groove.
oh, and your cover is totally different than mine, it sticks out farther on your idler. it even seems that the idler is bigger in diameter ( but not really sure on that).
I spaced the idler out different today and moved it slightly close in towards the bracket.......that helped get it away from that dust cover, but the tightest I could get the belt underneath the car was a little under a 1/2" of tension.....I drove it around like this for about 20mins, then blipped the throttle a few times and it still gave the same feeling......
Also, I ran out of gas as I pulled into my garage...........******* great......
I put A LOT of fuel in my car and didn't think the gauge would be this off......fuel pump started making a lot of noise and the regualtor was making a whirling noise, as I was PARKING THE CAR in the garage fuel pressure dropped to 45psi and stayed there, so I shut off the car right away.......my 420L single sounded different till I primed it a few times......car didn't have any problems started up and idling, should it be oK?
J
If the belts are jumping teeth at a 1/2" tension, wouldn't it be worse even more loose?
I can get more tension on the belt and get it possibly down to 1/4" tension if I put it up on the lift and really get at it.....
Any suggestions.....
J-time for one of these
Anyone think if I loosen the belt to 3/4" it could get better or no?
It seemed like it was somewhat better today slipping wise, but nothing progressivly further with the situation, Its got to be jumping for some reason, and I can't for see it holding better w/less tension....
My mototrons will be here this week.........
Just need to get these COGS straightened out.....
Hello Jeremy
Regardings your cog belt you should tension it too tight but not super
tight. 3/4 to 1" are fine. The only way you will loose a belt is that when
you go WOT and have a backfire that where you will loose a belt (striped the
cog teeths) So make sure your car is tuned.
Bruce
So I am going to stick with the amount of tension I have now for the time being. I will go tighter if the car shreads the belt.
J
Took the car out this morning, fuel system seems to be fine, put another 5 gallons of 100 in the tank....so thats A ok......
When I was at the gas station I was reving the motor by hand under the hood.....and I was watching the whole COG setup while doing this.....as the motor torques to the side I can see the belt elevate from the blower pulley, its not slipping on the crank, just on the blower pulley........when the motor dives to one side it jumps off the blower pulley, then as soon as I let the throttle body go its back on again.......the belt is wearing fine just driving it around town.......but I was doing little throttle revs to 3K real fast and that seemed to make it jump off.........
It almost seemed as if the blower was moving somewhat and this could be possibly throwing the alingment off.........not exactly sure though....
I'll measure the tension when I have it on the lift tonight, see if I can make it any tighter......
I talked to Sikora on the phone, he might be able to get me in sooner than I thought, but if the alingment of these pulleys is off by 20 thousandths it could make it a problem...
I can't got WOT because I don't know if I currently have the fuel to support that, and the car isn't tuned.......so I don't want to take any chances.........
Again, when I read these cog threads I think that nobody seems to have the best handle on it yet until we see some numbers.
I'm running it over like Jeremy....I have not yet tried running it under, but I think I will run out of room to tension the belt......me and chris were talking about opening up some more space in the bracket for the idler cog pulley to have more room to move either up or down.......what ever we decide on....
Either way I know we can get it to work.......just needs some tweaking....
way ATI mounted it. The tensioner for the cog, hits the stock idler pulley when trying to push it up and out of the way to get the cog belt ran underneath it. I ordered a new belt, and when it comes(tomorrow,hopefully) in I am going to add about two more spacers to the standoffs to push the bracket out even further to clear the stock idler and be able to push the ATI/cog tensioner out of the way. This is where the limited belt lengths come into play, we need one that is just 1/2 to 1 inch longer than this one but there is nothing available between the size we have 960 and the next size 1040. I am sure I will get it figured out soon. I already elongated the tensioner slot on my bracket to lift the tensioner higher(clint had to do this to his) and Boss might need to do that too.There is such a small distance from the s/c cog and the crank cog(10.5 inches) that running the belt on top of the tensioner even though it works, doesn't provide the belt wrap needed to keep it from lifting on the s/c on a quick rev. I haven't expirenced this but Bos has. So getting it to run normally is the best way, I'll have it figured out tomorrow.
J
I wasn't excited about taking the blower off to put the belt back on when I had accomplished nothing......I tried pushing as hard as I could to get the tensioner to the top of the slot, I don't think I can push it any farther up, I can't tell for sure though if there is room left to move......I can only go so far before I hit that stock idler...
Like you said, having the belt under would provide more wrap and no worries w/the damn idler.....
J
I got it up as far as I could with the handle of a 1 inch ratchet(fits better between my trannylines and crankcog). Then tried to turn the engine over to force the belt on that way. NO DEAL things got tight in a hurry and started to put some stress on things. So I backed it off and put it back on the way I had it.
BUT the solution is pretty easy, open up the tensioner slot even more. I thought I had it opened quite a bit but it has to be opened even further.
I have plenty of space between the tensioner and idler
You have to look close...
That looks to be the ticket.
J
I might have to have that one side of the cog idler machined down to clear the stock idler.....doing that and adding space in the bracket to move that idler up even more should give me more tension....
Jeremy, was the original problem w/running the belt under the tensioner is that the belt wouldn't fit or was it that there wasn't enough tension? I e-mailed lee on my side of the story, he hasn't gotten back to me yet......
Now if I wanted to get more space between the idler and tensioner thats an easy fix too, I just have to add one more washer to the standoffs, to open it up more than what I show in the pics.
If you lengthened the slot and added a washer or two to each stand off you will get the space between the tensioner and idler that you are looking for. You will also be able to run the belt like it was supposed to-under the tensioner.
Hope that helps. The real question is how much more do I need to lengthen that slot, I am thinkin about a lil more than .5 inch.
J
