What should I dyno?
Old Aug 7, 2011 | 01:34 PM
js2fst's Avatar
Default What should I dyno?
P1-sc 10 lbs(any gains lower rpm's with d1-sc) procharger fmic, 8 rib, 42lbs injectors (80lbs ordering do I need on this set up?), dual pumps, 03 Z06 cam, pp intake 85, rails, pp 85 tb, meth, ory, dynatech headers, cat back, fabbed 9 in 3.89 gears, built 4l80e, yank py 3600. Sd 2 bar. Full suspension car. Can't decide on putting my ported 317's on with 1.85 arms stock 00 longblock. Thanks for your help!
Old Aug 7, 2011 | 04:32 PM
old motorhead's Avatar
You might mention what engine all of this is going on. Compression ratio? 10psi on just about anything is going to outrun 42# injectors.
Old Aug 7, 2011 | 04:58 PM
js2fst's Avatar
It is a stock ls1, I think the 1.85 arms and 317 heads would give a little extra hp. But it would drop my compression some. Better flow and more lift would lower my boost level. I also worry the fmic might drop some boost. So I might need to repulley for more boost. I just do not want to much rwhp for stock motor.
Old Aug 7, 2011 | 05:19 PM
yessir's Avatar
..........impossible to estimate will all those damn variables..... soooo how z bout u put it on that there dynomamomiter thingy and tell us what it made
Old Aug 7, 2011 | 05:31 PM
js2fst's Avatar
Trying to get car finished befor we tune
Old Aug 7, 2011 | 05:35 PM
JRENIGAR's Avatar
450rwhp with conv unlocked...
Old Aug 7, 2011 | 05:43 PM
js2fst's Avatar
We did 437 before cam, 4l80, fmic, meth, and 7lbs.
Old Aug 8, 2011 | 04:54 PM
JRENIGAR's Avatar
525 unlocked or 560 locked...
