New PB in the turbo Firehawk
QA1s on all for corners. MWC fab 9 spool and 3.25 gears. BMR drab bar. currently has a set of 325 50 15 M&H tires but I also have a set of MT's the same size on a spare set of rear wheels
Thanks. it has been a long time coming. This thing is gonna haul the mail when its dailed in.
I had a 2 step just waiting to get it back. I know I can build boost on the trans break with out it but it is un controled and I will just blow the tires off.
I wouldn't due anything bigger than a 370 with this turbo. I will also note that I think this things would be too laggy for a M6 car. I don't mind this thing being laggy on the street helps with traction but man does it come in had when it hits boost.
How you like the M&H's? I love my hoosiers, I am trying out different brands than the more common mickey t's like the hoosier and maybe the M&H one day.
If you do build boost on the trans brake and your just out for test and tune screw the r/t and watch the boost gauge. When it gets to the boost level you want let off the damn button!
Spool I don't notice unless making hard and tight turns namely in parking lots. If you run the spool and a bias ply tire you can barely tell it is there.
The M&H tires aren't bad. they are lighter than the MT's some guys really like them. I got them from a buddy and they only had 2 passes on them. Not sure if I will just get a MT or a M&H again next. I think I have enough tire to last the rest of the year. so I will need new ones for next season.
I know I can sit and wait however aparently I waited to long for the track one time and they I made a pass and got no time.
I did sit longer on my second pass of the night saw about 4-5psi and just spun. I still need a little suspension work and a better track as it just spun.
#32
Man I want a MWC 9"!!! How does the spool drive on the street namely in reverse?
#34
Yep trans brake just not up on it very hard. Car has more in it. In good news my new 2 step with some updated/proto type internals is on its way back to me. Hoping to be back out for some testing in week or 2
