New PB in the turbo Firehawk
Also pass was on about 14 psi maybe 15 as far as I can tell but I forgot to log that pass and the vac line came off my wastegate so I am not sure. If was my first pass off the trailer
60'- 1.634
330- 4.328
1/8- 6.401
mph- 119.69
1000'- 8.165
1/4 9.654
mph - 152.21
I made 2 other passes.
Spun out of the hole bad on pass number too and aborted.
3rd pass went a 1.7 60' and I got on and off the throttle in 3rd since the car got a little squirly. Still went a 9.9@147mph. Not sure of the break down of the rest of the slip as I need to get it out of the car still.
Here is a video of my last pass. They missed getting my 2 other passes.
http://www.youtube.com/watch?v=upifTK2x8R8
For those that don't know.
Forged 347 Diamond pistons callies rods stock crank. AFR 205 heads. 9.6:1CR Virginia Speed cam, Vic JR and arrons elbow. Home built PT88 truck manifold kit.
Motor assembled and tuned by me.
Couple of questions:
What is the exact torque converter set up?
How do you like the spool up of that 88mm turbo?
Do you plan on turning up the boost more?
I am runnin a yank 3400 stall. Spool is a little slow but I think that will be improved with changes tothe tune and timing. I have left my timing unchanged so far from when it wS procharged. 152mph should get me to. 9.1 or 9.0 easy with a better 60'. Ca is really lazy off the line with no boost. I tried to launch on 4psi this same night and just blew off the tires.
I do plan on turning up the boost and maybe doing a race gas tune in the for a nice cold MIR rental and let her eat
Thanks
I am fighting the same issue.
I am about to upgrade to a 99+ pcm and then I'll be able to utilize a custom os with efilive with a boost timing table and put more timing to it down low.
What tuning software are you using?
Thanks it really not as easy as I made it look
I am using HPtunners. I have had the 2 bar OS for over 3 years now. Its not that I have been fighting the issues I have just haven't sat down to play with it. I have been dealing with 2 step issues it has been a long battle with that.
VTC 2
If I missed it sorry how much boost down track?
