Motor running too hot
Old Aug 17, 2011 | 11:17 PM
ivan c's Avatar
Default Motor running too hot
1994 Trans Am LQ9 stroker 8:2:1 compression eagle crank, scat H-beam rods, mahle pistons, dart heads, LSXR intake, D1SC pro charger 9 psi, intercooler, big stuff 3, turbo 400 3-speed transmission.
Car made 660 rwhp with 6 speed transmission. Runs great but I have a problem with temperature. Highway speeds running about 230-235, cruising in town I am getting about 260. I have 3 core griffin radiator. Single fan due to blower being in the way. Took out my fog lights for better air flow. I am still running too hot.
My radiator is from my LT1 setup which was reversed flow. Would that have anything to do with the temperature?
Any suggestions out there? Thanks in advance.
Old Aug 18, 2011 | 06:01 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Have you made sure the fan is pulling air through the radiator, and is not spinning the wrong way? Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Aug 18, 2011 | 09:16 AM
ivan c's Avatar
Yes fan is pulling through rad for sure
Old Aug 18, 2011 | 09:32 AM
67RSCamaroVette's Avatar
The last ProCharged car that rolled in the shop, I added a derale 10" fan to the upper driver side shroud, made it slightly better. 160 thermostat, slightly better. Lowered idle from 850 to 700, bam, idle overheating issue all gone. Make sure your fan shroud doesnt have any gaps where it meets the radiator, you need all the CFM you can get.
Old Aug 18, 2011 | 02:47 PM
Old Geezer's Avatar
Check the gauge accuracy...
Old Aug 18, 2011 | 04:23 PM
stevieturbo's Avatar
Above 30mph, the fans do **** all anyway, other than restrict the natural airflow.
Old Aug 18, 2011 | 05:05 PM
rotary1307cc's Avatar
Epoxy core griffins are a joke
Old Aug 18, 2011 | 10:24 PM
black98ws6ta's Avatar
260 is way too hot...dont let it get to that point.
Old Aug 18, 2011 | 10:34 PM
KingOfCold's Avatar
I had a similar overheating problem because I had air trapped in the cooling system. Jack the front of the car up a few feet, start the car and let it idle with the rad cap off until it reaches operating temp. Add coolant to the radiator and put the cap back on before lowering the front of the car again.
