Procharged LT1 build
-383ci 10:1 CR
-Dragonslayer crank
-compstar rods
-custom CP pistons
-Splayed billet caps
-AFR 210cc heads
-LE ported intake
-LE blower cam
-P-1sc @ 10-12psi
-ATI BB LT1 hub
-ATI super damper
-24x
-stage 2 snow performance kit
-pacesetter or LPP headers (if i can find a set)
-60# injectors
-duel intank pumps
some parts i already have, such as the SC so i really dont need the P1 vs. D1.
-383ci 10:1 CR
-Dragonslayer crank
-compstar rods
-custom CP pistons
-AFR 210cc heads
-LE ported intake
-LE blower cam
-P-1sc @ 10-12psi
-ATI BB LT1 hub
-ATI super damper
-24x
-60# injectors
-duel intank pumps
Are you using a intercooler at all?
You should have some good power numbers with that combo.
also i have seen your advice over on LTxtech, just posted on here to get more input.
-Tony
-Tony
Boost is crazy once you get a taste you'll crave for more!
