How much seat pressure O/C on a turbo car at 20+psi
How much seat pressure do you guys run on your valvetrain open/closed in a hydraulic setup with cars making 800 or more? I'm beginning to question mine as the heads are at the machine shop right now. The car see's 20+ psi on a 408ci motor. Is there such a thing as too much seat pressure?
Morel lifters, titanium intake valves, sodium filled exhaust, stock Ls3 rockers.
Yes you can have to much seat pressure, especially on a hydralic roller setup.
On a hydralic roller around 170-175lbs on the seat. You can go a little higher but then risk the chance of bleeding out the lifters.
Chris
Chris
20psi of intake pressure but probably double that on the exhaust valves. What style cam lobes are you running? HUC lobes are very smooth / stable for high rpm. I think most turbo setups float the exhaust valve while trying to stay seated. It's not 20 lbs of pressure either you have to multiply pressure x surface area. Here is a great post explaining the math https://ls1tech.com/forums/14657390-post4.html
Exactly, it's valve size, weight, lobes(to an extent) and pressure/back pressure.
My cam is a virginia speed vtc4
7 Second Club
Sorry got tired of waiting.... A 1.60" circle is 2.01, 2.01 x 50 = 100.5# of pressure. I understand that number is not going to be exact but by the time you subtract the stem area plus the backside of the valve is not flat, its close enough. So your reducing the pressure of the valve springs by 100#.
From the link, 15 psi on a 2.05" valve:
2.05" intake valve, then the radius = 1.025"
So the Area = 3.1415 X (1.025" X 1.025")
or
3.1415 X 1.05 = 3.3 (rounded up a tad)
So if you are running 15 psi of boost, then the extra force on the face of the intake valve is 3.3 X 15 = 49.5 pounds.
Now back to your example:
So if you take that on the exhaust valve: 1.60 radius is .80 so area is 3.1415x (.80x.80)= 2.01
2.01x15 psi= 30 ish lbs. So you are reducing your spring pressure by 30 lbs, not 100.
Let's go one step further and imagine that you are running a TINY turbo and backpressure is double boost (not unheard of) That would at more be 60#. A good bit more, but still not 100#.
or
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
No and I agree...but a lot of people run a turbo that I would consider to be a bit small and a turbine housing that is generally way too small for a good performance motor. I tend to size the turbine a bit bigger in hopes of getting close to a 1:1 backpressure or less. That is one reason why I am still considering running dual T4 turbos or a single T6.
Edit:
Ah, you are talking area, not the size of the valve. My bad. Are you really seeing 50# of back pressure in your turbo set up?!?
