Need some help Procharger
Old Sep 1, 2011 | 01:23 PM
4kiro's Avatar
Default Need some help Procharger
I was checking my fan connection because it's not turning on causing my car to overheat. Noticed I need to replace my belt. Was looking and really didn't see a way to change the belt without taking out the procharger. I am a newbie and I have a f1a
Old Sep 1, 2011 | 01:51 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Yes, you unbolt the blower to replace the belt on a 98-02 F Body. Shoot me an e-mail to brutespeed@gmail.com and I'll send you a copy of the ProCharger installation instructions. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Sep 1, 2011 | 01:57 PM
4kiro's Avatar
Ok I will. One more question, how much psi should I see if I have on a 5.25 pulley. Currently seeing about 6. What if I replace it with a 4.75 pulley.
Old Sep 1, 2011 | 02:01 PM
LS1Tech Sponsor
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
If you have a stock bottom end (not forged) I'd leave the 5.25 pulley on for now and get the blower belt tight (as tight as a guitar string) and make sure the air filter is clean. A dirty filter restricts boost. Now see how much boost you're making before you go and swap pulleys. If you're still at 6 psi then I'd drop down to a 5.00 pulley. Bob
__________________
Old Sep 1, 2011 | 02:22 PM
4kiro's Avatar
Kool my engine is stock, it's got stainless steel headers 1 7/8 with three inch exhaust no cats. Just bought some 317 heads that I am going to be porting and plan on youre blower cam with 100 percent meth. My car dynoed at 509 at the wheels.
Old Sep 1, 2011 | 07:37 PM
4kiro's Avatar
Bob how long does the belt need to be, you told me once but I forgot. If you have a part number it would greatly be appreciated.
Old Sep 1, 2011 | 07:40 PM
LS1Tech Sponsor
For your current 5.25 pulley the belt needs to be 42.70" long. Bob
LS1 F-BODY 8 RIB BELT / PULLEY MATRIX
Matrix for 7.65" crank pulley DC017A-008
ATI Dampner #918853
CRANK PULLEY BLOWER PULLEY BELT
DC017A-008 DP340I-08D DB392I-008
DC017A-008 DP355I-08D DB392I-008
DC017A-008 DP370I-08D DB400I-008
DC017A-008 DP385I-08D DB400I-008
DC017A-008 DP390I-08D DB400I-008
DC017A-008 DP400I-08D DB400I-008
DC017A-008 DP413I-08D DB408I-008
DC017A-008 DP425I-08D DB408I-008
DC017A-008 DP438I-08D DB415I-008
DC017A-008 DP450I-08D DB415I-008
DC017A-008 DP463I-08D DB415I-008
DC017A-008 DP475I-08D DB415I-008
DC017A-008 DP500I-08D DB415I-008
DC017A-008 DP525I-08D DB427I-008
__________________
Old Sep 1, 2011 | 07:42 PM
LS1Tech Sponsor
You're going to make some good power with that combination. Make sure you use 100% methanol, as the water in a 50/50 mix tends to put the flame out under boost. Bob
__________________
Old Sep 1, 2011 | 09:04 PM
4kiro's Avatar
Bob you are the man. Can't say it enough.
Old Sep 2, 2011 | 02:24 AM
LS1Tech Sponsor
You're welcome, thanks! Bob
__________________
