not making sense anymore.. help
now with all that being said, how long would a turbo take to clear oil out of the turbo if the restrictor is working and the turbo is oil soaked from before i would think it would burn it off with a few mins but, and if i leaked oil once through the turbo for any of the above reasons would this instantly kill my seals?
It should be right above the turbo on the supply line. Since its above the turbo.
Next, i couldnt follow your post very well, (please space it out some next time
) But are you able to see where the leak is coming from? Where is your feed line coming from? did you drill and tap the block off above the filter?If so, have you made sure thats not leaking?
Im completley lost, i ran a -4an supply with no restictor and a -12 to the pump and a -10 from the pump to the motor, i NEVER dropped a drip of oil. Returned it to the valve cover back then.
OP, move the checkvalve above the turbo, as close as humanly possible to turbo inlet, and their is no need for a restrictor, -4 is about the standard, maybe a -3 the least.
the feed line does have a one way check valve about 1 inch from the feed flange on the top of the turbo, it has a 1psi cracking pressure. it seems to be working fine, if i unbolt it nothing flows out but its obviously putting oil into the turbo
im not getting any leaks in lines or anything its all coming out of exhaust exit side of turbo, maybe compressor side too but hope not
the feed line is directly on top and is as straight up and down to the return being on the bottom as possible, i currently dont have a phone or camera or id take some pics : \
for the return line i originally didnt have a check valve in it thinking the pump would hold off the reverse flow after shutdown but i figured i could try since im still having problem with it,
as of today i narrowed it down a little more, started the car for the first time in a few weeks, finally got off and time, as soon as i fired it off it blew about 1/4 to a half of quart of cleanish oil out of the exhaust side onto the ground, after driving around and clearing up it hasn't dripped at all since then, i drove the car to work and have parked it and when i get off im see if it does the same thing on start up as it did at lunch
98Z28CobraKiller, when u say T flange u mean my T4 exhaust flange on my turbo bolts to the hot side of my exhaust flange or were the oil lines bolt too?
i did the oil restrictor and return line check valve at the same time would you guys recommend taking the return line check valve out and trying just the restrictor in the feed line if this problem persists then and see if that fixes it?
thanks all!
That check valve on the return is more then likely your problem.
Also, where does your drain enter your pan?
The check valve on the feed is fine. The one on the return, before the pump, is NFG. If you are going to have one, you want it right AFTER (outlet side of) the pump. Can you put the scavenge pump on a switch and run it for a sec after you shut the motor down? Basically suck the turbo dry before you walk away from it. Keep in mind that what comes out of the turbo is not as dense as smooth flowing oil. It is a frothy mess so you want free flowing, open volume of line between the turbo and the pump.
for the return i actually tapped the oil fill cap (yes not the cleanest way or best at all i know but did it so if i had to put engine back to N/A i can with out replacing a lot of stuff and i didnt have to go indepth in taking the pan off and all, kit started off as a cheap lets see if i can get the basics to work but) if yall feel this is the main reason i can get my pan tapped and fix this problem cause the return line does go along my subframe then up to the cap but
for the turbo angle the shaft is pretty horizontal and its all pretty well squared off for the feed/return being perpendicular and all.
if i had backed up oil in my turbo how long will it take to clear it all out if i fixed the problem? so i know how long to keep driving so if it is fixed i dont see left over and think its still doing it, my guess is a few mins of driving at operating temp but not sure
again this all helps so lol!
And a return line checkvalve is not needed. Mine left the turbo and went almost straight up to the pump and i NEVER had drain back,
ALSO, we had a problem identical to a problem you are having on a friends GXP we rearmounted, turned out, the guy who wired the pump for power wired it backwards and it was pushing oil to the turbo.
Check both of these things then get back to us.
this is when i FIRST finished it,dont have camera and phones down for a week or so so cant up load new pics but this is basically it, i have a diff turbo now diff hot side setup, same idea just a lot cleaner done and all but the oil lines are all the same basically, the return is a 90 degree though not a 45 and has the check valve installed right after the 90
and yeah i checked for the oil return back through cap, when i first did this i started it up and got a friend to watch the cap to make sure it came through, took a few secs but it comes out with out a problem
and new update as of this morn i drove it to work to see if it would act up etc, well it didnt leak any over night and on start up it didnt blow a ton out ether and didnt seem to leak any on the way up, when i take lunch im lookin over it all again, might be fixed for once
