370ci / PT7875 / 4L80e / Stock Heads / 706rwhp / E85
Well I finally got the car to the dyno, and I'm pretty stoked with the numbers. The car put down just over 700rwhp through an unlocked 4L80e at about 19.5 psi on E85.
Motor is a 370 with untouched 317 heads, Scat rods, Diamond pistons, LS6 cam, Patriot dual springs, Bosch 160lb injectors with Versafueler and twin Walbros. Trans is a home built 4L80e with a Yank 3600 stall (which will need to be tightened up with the newfound power, haha)
First pull was about 570rwhp on 14.5 psi. Ended up at 706rwhp on 19.5 psi. 20* timing. Made peak power at 6100. This was on a Mustang dyno that is notoriously low. For example, my buddy's track car is about 2800lbs race weight and dynos 800awhp and goes 167mph. I'm hoping for 145 in my 4200lb pig. I went 136mph on 550rwhp through the auto.
Scanner is on the fritz, I'll upload the dyno graph later Fixed. We also "dragged" the car on the dyno for the hell of it, lol. It ran a 6.1 @ 115 and a 9.66 letting out at the 1000 because I'm out of gear. Got my 28" tires coming. If I can run 9s and 140+ at the ACTUAL track, I'll be thrilled.
Thanks to a ton of help from the forum and to NicD for some injector help
NIce man!! look forward to seein some times.. i think once mine is done it will be close to running the same
i have a smaller motor but its goin to have more compression great heads and custom cam. so im hoping for good things for yours so i can get my hopes up over mine LOL
keep us updated
keep us updated
Bottom nines and I'll poop myself, haha. Might be able to get out for test and tune next Sunday. I'm not going to get many chances though before getting thrown out, no cage.
I haven't fitted the 28s yet. I'm going to just see how it goes once I get them mounted. I'm not too worried about it. At worst I'll have to make some shock relocators and get out a 3lb sledge... haha. I ordered M&H radials because I want a good street tire. They should hook better than my 26" MT radials do on the street and the track. Best short time with the 26" MTs was 1.61. I can launch on boost now so if it hooks it should go down a good amount.
^^ someone is looking to up their post count...
i will be watching for updates all around on this specially the tires.. I'm join to be learning all i can from you so i don't have as many problems LOL
if you don't hook up just sty out of it.. save running it out the back for a well hooking pass and let her eat..
got that 9
got that 9
