on3 turbo
Old Dec 7, 2011 | 11:21 PM
  #141
killernoodle's Avatar
Originally Posted by nxfirebird
not trying to stir the pot, but the on3 76 is 689.00, and i've found the tc78 for 799.00. so you save only 110.00 bucks, that's only one nights bar tab. soo why go with it?
Ball bearing vs journal? Journal bearing on3 turbo is much cheaper.
Originally Posted by Sarg
Some are, some are journal bearing. There was a guy on one thread that disassembled one of the ball bearing turbos and said it looked to be good quality.
That was me
Old Dec 8, 2011 | 05:49 AM
  #142
Sarg's Avatar
Ball bearing is in the $6xx where as the journal bearings go for $299-$325. While I have not looked lately, I remember the TC78 ball bearing being a good bit more.
Old Dec 8, 2011 | 06:42 AM
  #143
JAX04's Avatar
Yep, IIRC when i bought mine a year ago, they were listing for 500 more then a journal bearing turbo.
I didnt think we needed all that fancy ball bearing stuff in the V8 world, lol.
Old Dec 8, 2011 | 08:09 AM
  #144
RedRocketZ28's Avatar
Originally Posted by 82lsx cutlass
Yea I gave on3 a call they said the biggest A/R was a 96 for the t76. And that they were ceramic ball bearing turbos. So I guess ill be buying one!
What's the price they gave you? I emailed them and asked if they still made the non-ball bearing T76 with a .96 AR and they had a batch in progress. I didn't ask about the price as I assumed it was still going to be in the $300 range.
Old Dec 8, 2011 | 09:38 AM
  #145
Sarg's Avatar
They also make a 1.0x AR but probably don't have it in stock.
Old Jan 5, 2012 | 11:50 AM
  #146
2BAD4U's Avatar
Any new news on these turbos? Anyone get their set up running? Curious... Espcially with the twin 70mm 5.3L
Old Jan 5, 2012 | 12:34 PM
  #147
GM PHASST's Avatar
As told by one of our sponsors, a 65mm exducer will support under 600hp. Not sure if thats fw or rw. The 68mm exducer will support above 600hp, again not sure if thats fw or rw.
Old Jan 5, 2012 | 01:25 PM
  #148
Sarg's Avatar
It is going to be a minute on mine. Customer cars come first, and we have to finish shoe horning the 5.3 into my Wrx. That part is almost done. Hoping to have the transmission finished in the next month or so and then off to get the custom driveshaft made. The single on the 5.3 got scrapped, but that motor and transmission will eventually go in a 71 camaro.
Old Jan 5, 2012 | 01:44 PM
  #149
WheelsUp84z's Avatar
No dyno time, but i put a video up of it on the street. the 76mm with the .81 AR housing it putting out 17psi on my stock ls1. It will definalty choke the motor out over 6k, as I'm at full boost around 3600 rpms.
Old Jan 5, 2012 | 04:12 PM
  #150
tta656's Avatar
I think it was asked,is the ceramic ball bearing that much better then the journal bearing
Old Jan 5, 2012 | 09:34 PM
  #151
2BAD4U's Avatar
Yeah you need a bigger AR on the exhaust side i think.
Old Jan 6, 2012 | 07:20 AM
  #152
BOBS99SS's Avatar
Captain Double Post
wheelsup where is this vid at, i didnt see it on your build page?
Old Jan 10, 2012 | 12:11 PM
  #153
tripblackls1's Avatar
Are the turbine housing on these turbos divided ?
Old Jan 10, 2012 | 12:44 PM
  #154
2BAD4U's Avatar
I dont believe so.
Old Jan 10, 2012 | 01:01 PM
  #155
Sarg's Avatar
Some are.
Old Jan 10, 2012 | 01:44 PM
  #156
The bigger problem is that the exducer on the exhaust wheel is only 65mm. I wish it came with a bigger exhaust wheel, but the 76 should do fine in a rear mount situation.
Old Jan 10, 2012 | 09:42 PM
  #157
Bobsmyuncle's Avatar
I just got mine about a month ago, 70mm journal, and it has a divided housing. Place is local to me and always easily reachable via telephone. They told me they have made 680wheel with the 70mm journal. On a 4.6.
Mine is going on a 5.3 w arp stuff, sto k heads, vicjr, lpe cam.
Looking for 700wheel, I got the 1.0a/r
Old Jan 10, 2012 | 10:36 PM
  #158
ledesordre's Avatar
went with the 76mm journal bearing 1.0 a/r exhaust split housing...
still fabbing it.. here
Old Jan 11, 2012 | 02:29 PM
  #159
LSJM1's Avatar
I don't see the 76mm listed with a housing bigger than .81 does it cost more to get the 1.0 housing
Old Jan 11, 2012 | 04:34 PM
  #160
T76s10's Avatar
Just bought my 76mm journal from them for $348 shipped and they said they sell the 76mm's in .81ar and .96ar. Although the housing says .81 I know for a fact it's a .96 but they must not mark them separately. Going in my 5.3 s10 this spring so I'm hoping it'll make some good power
