402ci,TFS 225, APS W/LG turbos and 4L80
Old 10-11-2011, 07:32 PM
  #41
Fbodyjunkie06's Avatar
Shoot, I'd bring an Aero bed in that beotch, oh but that might raise suspicion from the misses, hmm she ever come out there?
Old 10-11-2011, 07:47 PM
  #42
tomz28's Avatar
dont worry about her. im going to upgrade that soon too. but i need this car done before its too cold.
Old 10-12-2011, 08:45 PM
  #43
tomz28's Avatar
well started to put the engine back in the car. its about time something started to work out
Old 10-13-2011, 06:58 AM
  #44
venom ws7's Avatar
Very nice man getting close
Old 10-17-2011, 01:56 PM
  #45
tomz28's Avatar
got everything back in but the starter was broke. so thats all i need to start it up
Old 10-17-2011, 07:09 PM
  #46
Louis's Avatar
Do work son!
Old 10-17-2011, 09:06 PM
  #47
tomz28's Avatar
few pics of my return lines and return pump setup.feel freeto input you 2 cents on the lay. love useful feed back
here is how the two lines come together
here is the turbowex pump
hard plastic lines that i use on must of the car. in my car every section of line (2 large sections) have a vac/boost gauge is i will aleays know if there is a leak. i use my Ebost for the side that has the FPR, and the gauge in the dash for the MAP, and blowoff valves
i run -4an line for my coolant crossover
exhuast layout
Old 10-18-2011, 04:17 AM
  #48
WheelsUp84z's Avatar
Looks good! I must say I dont like the position of that fuel line, If you ever hit anything or come down off a lauch, that could be disasterous. Also, where did you buy your vacuum lines from? I saw some similar on RPS's website, they look really clean, I'd like to use the same kind on my car.
Old 10-18-2011, 09:32 AM
  #49
tomz28's Avatar
you can get all the lines and fittings at fasenal. The fuel line has no play in it. it cant move up or down
Old 10-18-2011, 01:09 PM
  #50
Thanks for the tip. I wasnt refering to it as in how it was mounted exactly, more/less that it hangs lower than the K-member. Kinda just out there for something to take it out.
EDIT: just realized that y block is for turbo oil return...duh. Thats what I was referring to originally, not the fuel line
Old 10-18-2011, 02:01 PM
  #51
tomz28's Avatar
lol ok dont worry my huge trans pan hangs lower lol
Old 10-18-2011, 03:07 PM
  #52
02blackbeauty19's Avatar
Looks great, Tom.
Am I correct in saying that your turbo draining system is a -10 from each turbo > Y block > -8 hose > scavenge pump?
Old 10-18-2011, 03:34 PM
  #53
tomz28's Avatar
yes its -10 but its -6 to the pump and back to the pan
Old 10-19-2011, 06:12 PM
  #54
MY99TAWS6's Avatar
Wow been off the board and busy out here since moved out west but good to see your car once again close to running condition. We both had some bad luck in the past but hopefully behind you/me.
That is a shop to die for . My new house has a crappy small double garage. Hoping to build a killer garage shop at different location and a hoist would be high on my list so damn great to have.
I miss my 99TT its back in Saskatchewan in garage in old house which so far didn't sell and it can stay there likely over winter now it looks like. Just got too busy to bring it out to British Columbia this year.It seemed to be running pretty good when last drove it,decently crazy even at 10psi with the LG and 427. Shame ran out of time to dyno and track it before moved.
Having fun with the z06 here but it isn't that fast compared to the 99, but stock is kind of nice sometimes too. And now your truck ! Always something with these machines.T@ts and tires its gonna cost ya. LOL
Anyway as always best of luck with the car Tom old buddy and maybe you can come out and visit me next year.
Old 10-20-2011, 10:52 AM
  #55
tomz28's Avatar
what up AL
update got it running last night. had a few bug to work out but whats new
Old 10-20-2011, 01:14 PM
  #56
Do all the Rossler 4l80e's use that deep pan? Or just the ones that have rossler's transbrake?
Have you put anymore thought into using jakes valve body and transbrake? It doesn't need that trans pan, unless you like the added fluid capacity, as I have actually been looking at deeper finned pans to get some more capacity and heat dissipation in mine along with hooking up a constant on/off switch for my trans cooler/fan.
Old 10-21-2011, 09:04 AM
  #57
tomz28's Avatar
you dont need a pan this big. i had no idea it was this big until i got it. my trans after 5 back to back runs at the track only hit 170. my trans cooler dose all the work every well. it ties into the rad fans so when they come on the trans fan comes on
Old 10-21-2011, 11:03 AM
  #58
Yea my fan on my cooler is on a thermostat in the cooler itself and it kicks on at 175 and off at 170. I am going to wire up a hot switch that will allow me to keep the fan on while the car is cut off past 170, as it is now it will run even with the car off, but it cuts off when it hits 170.
Old 10-21-2011, 11:20 AM
  #59
tomz28's Avatar
good idea for sure. that pic of the Y-block, its only 3/8 of a inch below the pan
Old 10-22-2011, 11:52 AM
  #60
tomz28's Avatar
running good now, took forever to bleed all the air out of the block pita. ready for some driving
Quick Reply: 402ci,TFS 225, APS W/LG turbos and 4L80
