factory head choice, 15psi
Old Oct 17, 2011 | 10:17 AM
pdasterly's Avatar
Default factory head choice, 15psi
I have a forged ls2 403 and want to know which heads should i use for daily driver, street car. I have a set of ported 243's from corvette with sodium filled valves 64cc. Also have 317's ported by same machinist, guessing regualar valves 72cc.
car has max pullied d1sc, fmic
Old Oct 17, 2011 | 10:52 AM
MUSTANGBRKR02's Avatar
You need to figure what compression ratio you would like and pick the head based off of that. So you need to know a few things about the shortblock to figure that out.
Old Oct 17, 2011 | 10:57 AM
pdasterly's Avatar
9.1 compression ratio according to mahle, engine has factory crankshaft, forged rods and -20cc pistons. the pistons are oversized making the engine 403 cu in.
Old Oct 17, 2011 | 11:28 AM
turbo iroc's Avatar
I'm running l92 heads, can't deny the 265 CC runners and 2.16 valves. L92 ls3 and lsa there, hands down the best factory heads out there.
Old Oct 17, 2011 | 03:16 PM
killernoodle's Avatar
He may not want to change his intake manifold, or switch away from a head he already has.
Cathedral ports only?
I say 243s, with the 317s I bet that brings your compression down quite a bit with -20cc pistons. The fact that you want daily driver tells me you probably would like more compression better.
You should be fine with stock heads and LS9 gaskets and good studs at 15lbs.
Old Oct 17, 2011 | 03:41 PM
Head CC will make that determination along with how far the piston sticks out of the head, head gasket thickness and bore etc. Mahle gives a generic rating based on a certain CC head.
Old Oct 17, 2011 | 05:02 PM
L92 fox's Avatar
How is it a 403 with a stock crank?
Old Oct 17, 2011 | 08:44 PM
westtexasbuff's Avatar
LSAs ftw, they are casted with a better material than the LS3/92s and are 68cc chambers. Here are mine ported.
Old Oct 18, 2011 | 10:56 AM
pdasterly's Avatar
going to get some ls3 heads, I didnt want to change my intake, not to many aftermarket options. bbk should make a ls3 metal intake
Old Oct 18, 2011 | 11:17 AM
LSAs have the same rectangular port as LS3/92s, so you wouldn't have to change your intake. You can get them cheaper too brand new, I got mine $315 shipped bare for the pair.
Old Oct 18, 2011 | 06:18 PM
LSevil1's Avatar
Interested in this as well. 317's, in case you go to an F1, boost > compression on pump 91-93 oct.
Old Oct 18, 2011 | 06:53 PM
pdasterly's Avatar
my bad, I have a unknown engine size, seems online calculator is wrong
Old Oct 19, 2011 | 04:21 PM
If he currently has cathedral port heads/intake, he would have to change his intake for l92, lsa, etc.
Old Oct 20, 2011 | 11:10 AM
bonestock_442's Avatar
Who ported those LSA's WestTex? They look awesome.
Old Oct 20, 2011 | 02:33 PM
turbo iroc's Avatar
Don't forget you also need offset rockers on the intake side.
Old Oct 21, 2011 | 09:55 AM
My bad, I misread his post about going to LS3 heads, I thought he already had an rectangular port intake. But yepp, if he is switching then he will have to get an LS3 style intake. LS3 intakes are not that expensive, and work good.
Can't say on here, since he's not a sponsor, but it was a local shop here in town.
Old Oct 22, 2011 | 05:37 PM
PRAY HRD's Avatar
in your other post you said the lsa's were 68cc chambers, and i could be wrong about this, but when i was looking at the lsa heads months back i couldve sworn they were 75cc as cast. please correct me if i'm wrong.
Old Oct 22, 2011 | 09:15 PM
They are 68cc as cast, but can be 75cc with some work to them.
http://paceperformance.com/i-6255521...te-engine.html
"Cylinder heads - 12604860 aluminum L92 style with 68cc chambers"
Old Oct 22, 2011 | 09:41 PM
PRAY HRD's Avatar
thanks a lot man. i know i read it somewhere they were 75cc but that person was obviously incorrect.
