Interesting observation on non intercooled ATI
So now I guess I will look into doing some sort of heat sink or something clever like that to see if I can't keep the blower a little cooler. I can only imagine a 100 degree day. My friggen cruise inlet temps will probably be 150
Matter of fact I can usually tell exactly what the outside air temp is by subtracting 10 degrees from my IATs if I'm moving for a few minutes
The ATI will actually be a little cooler than the vortech. It is the compression of the air that is heating it up so much
I haven't gone into boost too much with the new setup yet. iat's fall dramatically because of the water alky but I hate the idea of them being so high when I first lay into it.
My blower is moving/compressing a lot of air at low speeds.I have a mondo bypass also.
A very quick blip in 1st gear and I saw 63+lbs maf flow at 5300rpm. The new 4" inlet and 2.5" outlet make for some serious airflow with the 2.5" pulley at low speeds. Pushing tons more air than the motor needs cruising around so the air just gets hot.
Not much you can do about the heat without an intercooler when spinning the blowers this fast.
When I used a larger pulley the heat was not near as bad.
Looks like I will need race gas full time as even the slightest throttle(50% or so) and it's at 6-8psi boost and it knocks on 93 pump gas at part throttle.
The alcohol will bring down the temps at wot. But really can't use it at low throttle settings.
Putting a throttle before the blower will help but then your pulling vacuum at the blower inlet which can create problems with the seals and oil being pulled out of the case.
Such is the problems of a lot of boost and no intercooler.
I have not even laid into it yet with the new combo. Just getting to much KR right now at part throttle. I'll put in some 100 octane fuel and see if that helps.
But it looks promising.Throttle response is wicked.
Steve
I don't want an intercooler.
Chris - yah I guess it was just panicking on my part. I never saw IAT's that high with the PD but of course it was pullied for a whole lot less boost
as for your previous question. little 3rd gear spurt this morning. start, IAT 108, end IAT 88
How much boost do you see at 50% throttle at around 4500rpm?
Right now I have my system on a WOT switch. I could hook it up to a hobbs switch and have it inject as a function of boost so I get flow at part throttle. But I'll need a bigger tank as mine only holds 2 quarts.
I may try it though just to see how it works to see if it stops my part throttle KR.
Yes, injecting at part throttle. NO part throttle KR under boost.
50% throttle at 4500rpm is about 6-7psi.
I was always suprised you used a wot switch knowing you could produce plenty of boost before the pedal was to the metal
I would definetely start injecting at part throttle. I have it kick on low as soon as I see any boost, kicks on high at 5psi. Works great! No bog, No KR, just goes. I use a 5 gallon fuel cell located in the hatch so I have no worries of running out too fast
Is your system always under pressure? Do you use a solenoid?
I have my pump gravity fed and the tank and pump where the battery was. It only has about 8" of line from tank to pump.
Then about 3ft of 6AN to the nozzle block whcih is right after the blower outlet. At the nozzle block is my return line with a .042 jet to build about 100psi+.
Blower pressure will blow the return line clean but it can't blow the pump to nozzle line clean as the pump has a built in check valve that will hold 100psi.
The system builds pressure just about instantly when activated.
I also have a manual button in car to over ride the hobbs switch. So I can always test or prime it.
I took apart the built in pressure switch assmebly on the pump which is bypassed and put a Normally off switch inside.
This is wired to an indicator light in car to let me know the pump is both operating and building pressure.
On my old low comp AFR head 383 LT1, I ran 8lbs with an S-trim non intercooled.
IATs hit 220*F at the top end of the 1/4
. My IAT was actually running hotter then my coolant on that run lol. the longer I am in boost, the lower they go.
a 3rd gear romp this afternoon took them from 141 to 99.
Steve - I was wrong. Today I saw 5psi at 50% and 4500rpm
I tried the part throttle flow last night with just water. I had the switch set to high at 5psi. So water did not flow before it knocked on most instances.
Amazing that at part throttle with 15GPH pure water flowing the motor did not stumble,surge or anything. Iat's stayed around 105 at part throttle boost vs 150 the other night.
I'll do more testing and get it to kick in sooner.
I'm running about 24 degrees timing at part throttle boost and pump gas can not handle it.
Thats where the dual stage controller comes in. With it I don't have to worry about bogging the car down with too much flow in the low boost situations but I get the advantage of enough flow to keep KR away.
