A year ago today I took the stock shortblock record...
Old 11-10-2011, 03:20 PM
  #181
black98ws6ta's Avatar
Originally Posted by 71 chevy
question - what does your car weigh?
i was watching a 275 race saturday and the cars had to drive over the scales each pass.
the heaviest mustang with driver was less than 3050 - this was stock factory glass, all steel except the hood, two alum seats, and interior plastics in place
im wondering, how easy, or difficult would it be to get a fox body to a 2600 lb raceweight?
3250. The hatch cars are heavier then the trunk cars and my car has the soonroof which adds weight as well. Just like anything else you can spend a bunch of time and money and get one lighter. This car is really too nice for me to want to cut up and make lighter.
To get to a safe 2600 lb raceweight in a foxbody you would have alot of time cutting and a ton money in lightweight parts.
Old 11-10-2011, 03:38 PM
  #182
skinnies's Avatar
I'd say 2600 is doable in a fox, just like Anthony said tho would be a lot of cutting/light parts. I've considered selling my rx7 a few times to get a fox, I really love how the fox cars look, I just know I'd be giving up some mph going that way so can't justify it yet. We have a fox we are building for a guy right now, 6.0/88mm, I'll have it on the scales soon to get an idea what it weighs. Also remember my aluminum motor and 76 is probably 100lbs lighter than a 6.0 and t6 88mm.
Old 11-10-2011, 11:12 PM
  #183
71 chevy's Avatar
two of the three stangs that i saw get on the scales were hatchbacks. BUT, they were nitrous smallblocks, and the drivers were less than 200lbs. i think the intercooling stuff and turbo piping adds to the weight of the cars.
btw, here is the race. it was awesome seeing these cars on 275s running 1.2x 60s and 5.2s in the eighth. the final race was two hatchbacks and it was close as heck
http://www.youtube.com/watch?v=jEuXR...ature=youtu.be
i love how the fox hatches look too and im going to do a turbo foxbody hatch. they work too well. if you look at the vid i posted above, i talked to the two finalists through the night and its sickening how little it took to get those cars working. both cars had upgraded uppers and lowers, but stock mounting points. arb, coil overs and frame connectors and thats it. and these guys are 60' in the 1.20s on 275s. they are even using the 8.8, albeit beefed up.
i think 2600 raceweight with a sub 200 driver would be doable(but not easy) if it doesnt have to fit a class. alum block engine, lexan windows all around. pro stock radiator, lightened doors,etc could probably get there.
skinnies, do you run a glide or th400?
Old 11-10-2011, 11:45 PM
  #184
skinnies's Avatar
I ran a th400 last year and a glide this year, honestly I like the glide and I know once it goes straight it'll work great! We also strapped down the front end this year, has about 1/2" travel up and still will take everything on the hit that we have thrown at it.
Yes mustangs are easy to get to hook, such a great chassis and I do like the looks of them. I have a white notch in my garage we are building for a guy, 6.0/88mm combo, should be out in spring(since its getting cold here and tracks will be closing). I'll be disappointed if it doesn't run in the 8's, lol.
Old 11-11-2011, 07:22 AM
  #185
71 chevy's Avatar
thanks for the info. im contemplating switching to a glide too. it goes just as fast/faster and will cut some weight
Old 11-11-2011, 10:25 AM
  #186
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,143 Likes on 743 Posts
Cool, don't be afraid to give Eric a call though, he lives for this stuff and he's helped guys like Andy who isn't even running any of his stuff (yet).
Is your suspension adjustable?
Do you think you are out of turbo and could you run a bit bigger one you think? I'm also curious as to why you like the 'glide more, is it happier with it in terms of power band?
Old 11-11-2011, 03:46 PM
  #187
skinnies's Avatar
Yep it's a full 4 link car and definitely think its out of turbo. Above 20lbs it didn't gain nearly as much per lb of boost, honestly I think an 88 would be ideal for this motor on around 24lbs or so. I was planning on turning the car up last weekend, but they wouldn't let me make anymore passes, was going to try to push it over 170mph.
I put in the glide to help keep the nose down, which with it and the front end limit straps seemed to really help, plus it helps on the street. The cars never been to a chassis shop and I'm far from knowing enough on a 4 link car to make it right so I'm pretty excited to get that done.
Old 11-11-2011, 04:04 PM
  #188
94'BLKBRD's Avatar
Wow ....I remember your build thread of your lt1 trans am a couple years back, ran 10's with the turbo lt1 right?
Turbo headers or truck manifolds on the rx7?
Old 11-11-2011, 04:20 PM
  #189
skinnies's Avatar
Yep I had the turbo lt1 formula before, I run a truck manifold on the passenger side and drivers side is a car manifold facing towards the back of the car in order to keep the stock alternator location.
Old 11-11-2011, 06:35 PM
  #190
JAX04's Avatar
pic??
Old 11-12-2011, 09:52 AM
  #191
skinnies's Avatar
Originally Posted by JAX04
pic??
Pics of what?
Old 11-12-2011, 07:32 PM
  #192
oneoverwrx's Avatar
Do you think a 76gts will be good for a 4.8? I feel like all the 5.3 guys run a pt88. I know you have done well with the 76 and I am hoping I can do well with a 76gts and a 4.8.
Old 11-12-2011, 07:44 PM
  #193
JAX04's Avatar
Pics of what?
Under hood shots... Just curious. Love to see different turbo setups
Old 11-12-2011, 11:38 PM
  #194
MaxxMitchell's Avatar
Skinnies is running a pte 76hpsh, the 76gts is compareable and will make pretty good numbers on a 4.8. Depending on if you are more street or track oriented will decide what a/r you want.
Old 11-13-2011, 08:30 AM
  #195
oneoverwrx's Avatar
What is the difference between the two turbos?
Old 11-13-2011, 09:32 AM
  #196
skinnies's Avatar
I really don't have many under hood shots of the car, here is an older one, but don't have any new ones since we changed some stuff around....
Old 11-13-2011, 10:24 AM
  #197
bluchev's Avatar
Are you using the stock pcm? What are you using to tune it? What size injectors?
Old 11-13-2011, 11:41 AM
  #198
dilsnick's Avatar
i might be wrong but i thinks its a stock pcm with hp tuners, and 80lb injectors.
Old 11-13-2011, 01:47 PM
  #199
skinnies's Avatar
correct
Old 11-13-2011, 03:55 PM
  #200
DFas's Avatar
Some fast cars hiding out. Hope to see some good competition this year.
Quick Reply: A year ago today I took the stock shortblock record...
