twin turbo and a 6 speed?
http://www.youtube.com/watch?v=7WGBwklqAPE
I'm going to steal a line from los here, but you guys that are so happy rowing gears and say auto's are boring have NEVER felt a 4500rpm 13psi boosted transbrake launch. If that don't convert you over you don't belong on a race track.
One more, 6 speeds impress high school kids, auto's win races!!!
I used to have a 6speed but once I hit over 700 rwhp I broke it 3 times. Broken synchro, broken teeth on a gear and then a bent output shaft.
Its a lot of fun hearing the blowoff on the street while shifting. I used to road race the car but went full out drag car. The big torque spike from the turbos made it hard to feather the turns with power. But I definitely had fun doing it.
If you are worried about your time slip to horsepower ratio, then go automatic, but if you really like rowing gears and don't care if you're maximizing your time slip efficiency, then stay a 6 speed.
And you are the one who busted out the "lame *** automatic guys"
You sure you dont drive a honda?....... Where it is cool to go slow because "it is different"
"Blowoff valve
From Wikipedia, the free encyclopedia
A blowoff valve (BOV) or dump valve is a pressure release system present in most turbocharged engines.
Its purpose is to prevent compressor surge, and reduce wear on the turbocharger and engine. Blowoff valves relieve the damaging effects of compressor "surge loading" by allowing the compressed air to vent to atmosphere, making a distinct hissing sound, or recirculated into the intake upstream of the compressor inlet."
back to the op's topic...if the dude wants a six speed let him do it either he'll have to be content on 9's or pony up with a th400 or 4l80 and go faster.
Its whatever suits your style and right now i could care less what e.t. my car runs. I use the track to see how healthy the car is and to see if i picked up any good power with the mods i do in between trips based off the mph i run.
Racejunky02, people have answered your question. More people run an auto into the 8's because its so much easier(and cheaper). YES you can run a t56 into the 8s but will it be easy? NO. Built 4l80es can be expensive but building t56s is also very expensive. Its all about the path of least resistance. You are also talking to a bunch of people who drive fbodies. These are not expensive cars by any means. Supras, vettes, and vipers are and the pockets (in general) run much deeper.
A custom stall for a 4l80e nearly the same price as one of the top dual disc clutches. You can pick up a running 4l80e for under 1000, you cannot pick up a good t56 for that, let alone get an 8sec capable one. And there is also the fact that our t56s are NOT the same ones that are in vipers, so you cant expect the same out them.
Its cool to be different but in this case its also more expensive.
Yes 4L80E's are expensive but odds are you won't break it if it is built right. A top of the line T56 and clutch are around the same price and you WILL break it sooner rather than later. Our 6 speeds just aren't meant to go 7's or 8's. The cars are too heavy and the trans is too weak. Sure it can be done, but who want to spend that much money to get a turbo F-body in the 8's just to say they did it? Not this guy.
Now if I was on a stock motor, or I intended on keeping a 600-650whp power level for a long period of time I would keep my 6 speed in a heartbeat. After that point it just isn't worth it to me. And no, I'm not building a race car. This is a street car that will see 10-20 passes a year most likely.
All that being said I am building a twin turbo 78 Trans Am with what.... you guessed it, a T56 LOL, but this will not be a drag car (at least not for the most part
)to the OP it truely is up to you, if you like rowing gears go for the 6 speed. As much as I love them though, I hated it EVERY single pass down the track. My next 4th gen (yes there will be another one day) will for sure be a single turbo/auto car
