Guys running LS7/9 head gaskets...
I know skinnies runs a stock 5.3 block with LS7 gaskets, but I'm wondering if he just slapped some LS7 gaskets in there and called it good, or if he had machining done.
I pulled some graphite gaskets off of my LQ4, so naturally I am curious as to what most of you are getting away with.
Now for the comment of running a ls7 gasket on a 5.3...... ok the ls7 is 4.125 bore and a 5.3 is what? Its under a 3.908 ls1 bore I know for sure soo how well would a head gasket with over a quarter inch bigger work?
As for ls9 head gaskets, I do truely believe that a ls9 gasket vs. A 6.0 mls would hold more power on a boosted app. Mainly because gm made that gasket just for a boosted app,it even says "supercharged" on the gasket. I've heard myths that someguys have hit over 900whp and not pushed water with 317 heads an zr1 gaskets.
