How hot does a turbine housing get?
Old Oct 31, 2011 | 03:31 PM
SPRAYED 01's Avatar
Default How hot does a turbine housing get?
I just put in my much larger comp 88mm for a test fit and the turbine housing is right on the fan housing. I can trim alittle plastic off but its pretty much going to be right on it. I'm going to have it coated also but a blanket won't fit at all. I'm worried about the fan motor which wil not be 1/4 inch away.
How hot can these get on the outside coated?
Old Oct 31, 2011 | 03:48 PM
Old Geezer's Avatar
1000* F would be somewhere in the ballpark. My turbo Buick ran egts in the 1550-1650* range...
Old Oct 31, 2011 | 04:20 PM
SPRAYED 01's Avatar
Hmm ok, I might have to figure somthing else out. I wonder what the coating brings the outside temp to. Probably still to hot for the fan motor
Old Oct 31, 2011 | 04:54 PM
Chicago TDP's Avatar
Well, that nylon that the fan is made out of will be liquid at 500F...
Old Oct 31, 2011 | 06:52 PM
turbo iroc's Avatar
Is there room to Fab up some kind of heat sheild? That's what I did, but its a good inch away from the housing.
Old Nov 1, 2011 | 08:17 AM
bboyferal's Avatar
The exhaust housing you mean? If so, wouldn't a turbo blanket take care of that? I can touch mine with my finger while it's running.
Edit: Ooops... I didn't read the part where you mentioned a blanket wouldn't fit. My bad... What a shame, that would certainly do the trick... You sure it can't be made to fit? If you can stuff it in there, they're really not that thick.
Old Nov 1, 2011 | 08:48 AM
Old Geezer's Avatar
Red face Yep..
On the GN:
1600* measured just under the turbo, and the coated dp close, [2"] to the plastic inner fender= "self clearancing" inner fender.
A ceramic coating will help, but not enough to prevent problems...
Old Nov 1, 2011 | 06:09 PM
10sec_rx7's Avatar
7 Second Club
ceramic coating wont do much at all,
these manifolds are ceramic coated..
Old Nov 1, 2011 | 06:12 PM
ledesordre's Avatar
that looks insane
Old Nov 2, 2011 | 07:57 AM
chuntington101's Avatar
Thats briliant!
Old Nov 2, 2011 | 08:26 AM
gimmeluvin's Avatar
Thats Nuckin Futs!
Old Nov 2, 2011 | 10:59 AM
narx66gmc's Avatar
Ohhh, I like it!! New screensaver!
Old Nov 2, 2011 | 11:12 AM
NemeSS's Avatar
Ceramic coat will flake off....eventually, may even void warranty of some new turbos.
Old Nov 3, 2011 | 08:20 AM
I always wondered why boats with enclosed engine bays ran water cooled manifolds..... i see why now! lol
Old Nov 3, 2011 | 04:44 PM
10sec_rx7's Avatar
7 Second Club
yep water cooler manifolds are a must, we made a new set in the off season with some bigger primarys and they dont glow as much now but still get the glow on when it is a little dark out... the longer races are 50min to 1hr long and they will glow like that the whole time.. lol
Old Nov 4, 2011 | 07:19 AM
LS AzZkIkr's Avatar
Post some pics of your setup.
