Starting my LQ9 build, please come in and advise!
Adding a turbo to my existing LQ9 powered fox body. Car goes 7.0's @ ~98 w/just the LQ9, headers and a cam. Going to add a B/W S475 to the mix and see what happens. Any input would be great. I have my converter out to be rebuilt for the new combo, any advice here would be great as it will need to be just right with no trans brake.
Stock LQ9 - 364ci (4in bore, 3.622in stroke) 10:1 c/r
Stock 317 cylinder heads - 72cc heads (2.00/1.55 valves)
Cylinder Head Flow:
Lift......Int...........Exh
.100" ..64.8........53.3
.200"..142.1.......111.6
.300"..204.3.......146.8
.400"..233.5.......164.9
.500"..250.0.......174.2
.550"..251.2.......181.2
.600"..253.0.......184.4
Test bore = 4.030"
Exhaust tested without pipe.
LS6 intake w/ported 78mm throttle body
TSP Tsunami Cam:
Cam specs: 235/240 648"/609",111 using Lunati's .660 spring kit.
Turbo Specs:
S400-75, 1.32ar, 96mm turbine wheel T6 flange
Running through manifolds, 2.5" cross over, 5" open downpipe. 2x38mm wastegates and 50mm bov
31x12x4" Godspeed intercooler, 3" piping
TH350 w/no transbrake, 3.73 rear end/spool, 28in tire
Car is probably around 3k pounds, going to have my current LS3 injectors resized to 80lbs @ 3bar by FIC, plan to run on 93 pump gas, fuel system consist of an Aeromotive Eliminator, -10 feed, -8 to each rail, Aeromotive boost referenced regulator, and -8 return. I tune myself using HP tuners and plan to run meth injection most likely with the 10:1 c/r.
Any suggestions on the converter and any input on my setup would be greatly appreciated.
Cylinder Head Flow:
Test bore = 4.030"
TSP Tsunami Cam:
Turbo Specs:
