Modular Turbo XT80 Turbo!!!!!
Old Nov 4, 2011 | 07:38 PM
ModularTurbo's Avatar
Default Modular Turbo XT80 Turbo!!!!!
The Magnum XT80 will be here in about 45 days.
Comp wheel specs: 80mm ind / 108mm ex 58 trim wheel
Comp cover specs: .60 a/r comp cover / Inlet dia. 5" w/ V band discharge
Turbine wheel specs: 77.5mm ex / 88mm ind
Turbine housing specs: T6 (T4) divided 1.05 a/r 1.22 a/r and 1.32 a/r
XT72 and XT76 will be available at the same time
XT88 will be due out in March!
MSRP $1100 for Journal bearing version
Ceramic Ball bearing pricing to be announced at release.
I will have one in our PRI booth some come by and check it out if you are going to be there.
I am going to have 10 turbos ready in January.
So here is a special offer to my LS1tech buds.
$1075 shipped if I get at least 5 pre-orders.
For the discount to take effect I only need 5 guys and it doesn't matter what size turbo you choose.
Old Nov 4, 2011 | 07:51 PM
JAX04's Avatar
any info on how much air it flows? What its rated at?
Old Nov 4, 2011 | 08:24 PM
gawath's Avatar
Ceramic Ball bearing Magnum XT80 for $1,075.00?
Old Nov 4, 2011 | 09:30 PM
eviltwin_1987's Avatar
Reading comprehension.
Old Nov 4, 2011 | 09:39 PM
1000RWHP capable
Old Nov 5, 2011 | 01:58 AM
gawath's Avatar
Look who's talking.
Old Nov 5, 2011 | 10:21 PM
Nitroused383's Avatar
1000 rwhp through a M6 or a stalled auto? How about flow in lbs/min? Any dimensions of the physical size or what it compares to?
Old Nov 5, 2011 | 10:44 PM
Its a T6 turbo close in dimensions to an S480
Old Jan 2, 2012 | 07:55 PM
Texhotrod593's Avatar
Rob, whats up with this? Also I heard through the grapevine there will be a magnum/MP 88mm release in march....is that true??
Old Jan 2, 2012 | 08:58 PM
Yes the XT88 is due out in march
Old Jan 2, 2012 | 09:58 PM
very nice...any specs as turbine sizes, t6/t4, a/r etc??
Old Jan 2, 2012 | 10:02 PM
headed-ws6's Avatar
Ugh rob tell them to stop making more sizes your killing me lol
Old Jan 3, 2012 | 12:24 AM
afastm6's Avatar
If u guys can find a way to front mount a 88mm without movin the radiator it would make a few ppl happy
Old Jan 3, 2012 | 11:31 AM
I updated the specs of the 80mm
The 80 and 88 will also be available in T4
We are going to use a larger exducer diameter.
the 80mm X 105mm comp wheel is being replaced by the 80mm x 108mm wheel
Also the 88mm wheels are done so expect the 88mm this spring.
Old Jan 3, 2012 | 08:09 PM
gnx7's Avatar
In a T4! Very good news.
Once you get one some weight and dimensions would be nice.
Old Jan 11, 2012 | 08:55 AM
Jefro6996's Avatar
Any more info on the 88? Very interested in running this with a 408.
Old Jan 11, 2012 | 07:20 PM
still working on it
Old Jan 13, 2012 | 07:21 AM
Jefro6996's Avatar
Ok thanks. Keep us updated....
Old Jan 13, 2012 | 08:58 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Man turbos are so much cheaper than blowers.... I'm jealous.
Old Jan 13, 2012 | 01:35 PM
Our hotside is cheap too LOL
