Turbo build
Old Nov 6, 2011 | 07:23 PM
audacious nick's Avatar
ASSuming On The Tree
Default Turbo build
So I am planning on building a budget turbo on my for-now stock LS1, running low boost until I get forged internals and 317 heads.
I would like to build a twin turbo, and I was thinking of using twin Holset hx35 turbos. Do you think the stock displacement is enough, or will their be significant turbo lag?
Also, I have read that buying the hx35w and bypassing the wastegate is a possible option, as it has a 12cm housing, vs 16 for the non-wastegate.
Is this feasible?
Old Nov 7, 2011 | 08:35 AM
This is going to be on an 04 GTO. I will be using C6 corvette manifolds as well.
Old Nov 11, 2011 | 12:00 PM
White40thGT's Avatar
What type of car and what turbo kit?
Any internal motor work like a cam?
What are you asking exactly? Will it work, how much power will it make? etc?
Old Nov 11, 2011 | 02:36 PM
It's in a 04 GTO. Stock engine internals. I am still deciding between the 243 ported heads I have, or 317 heads.
My question is if it will work well for a street car, as in not having terrible turbo lag, or if they're too small and will run out of steam quickly.
Old Nov 11, 2011 | 03:53 PM
Really can't say without knowing which turbo kit it is and more about those turbos. Your housings, piping, and turbo placement are going to determine if it will lag or run out of steam.
Is this a system you are building? Have you built a turbo system before?
Old Nov 12, 2011 | 10:52 PM
http://www.ebay.com/itm/CUMMINS-HX35...-/170722809040
That's the turbo I've been looking at.
And I haven't built a turbo system before, this is my first time. But I'm going to only tack everything up, then have a shop weld it up.
Old Nov 14, 2011 | 01:56 AM
I hope you have had some lessons in fluid dynamics and physics, building a turbo kit is not easy.
I'd never put those turbos on my car either.
Old Nov 14, 2011 | 09:59 AM
Anyone have any experience with twin turbos using those?
How about the ON3 turbos?
Old Nov 14, 2011 | 10:02 AM
Mightymike2000ss's Avatar
From: Home town Clive,IA current town FORT BENNING GEORGIA
Yeah man I actually found my kit on here for sale. Just make sure you have a very open minded budget because i originally had 5k budget.... broke that about the 4th month i started...
