Which rockers for a boost application (15-25psi or more)
Old Nov 15, 2011 | 06:28 PM
01 blue ss's Avatar
Default Which rockers for a boost application (15-25psi or more)
I'm building a 364 boost motor and going with PRC LS3 aftermarket casting heads. The plans are to run this motor with 15-25psi of boost, maybe more. The goal is to make a 32-3300lb race weight car go into the 8 second zone. My question is a simple one. I am trying to figure out which rocker arm system to run. I know the stock rockers with the trunion upgrade are being used widely but are they something you would use on a motor that I will be making this much power with. Should I go Comp pro mag or just go all the way and get the Comp shaft system? If it doesn't need it I would not rather spend the money but if thats what I have to use then so be it. Thoughts? Thanks guys.
Old Nov 16, 2011 | 05:56 PM
JPH's Avatar
JPH
What is the cam profile you will be running? And also, what valve springs? Pressures, etc....
Old Nov 16, 2011 | 06:49 PM
NemeSS's Avatar
I'm big on the Jesel SS rockers for the ls. I'm sure they may not be the best or lowest priced. But I built a engine for a car with these rockers. This was about 6yrs ago. The car has made 630+rw since. And 1000s of dd,track and road trip miles. My dd 500rw n/a engine also has these rockers, I sold this motor, but still in use today.It sees 7000+rpm shift points often.
Also have another set for my own turbo engine project. Since also plan on up to 7000+rpm shifts. And I know these rockers won't spill there bearings.
For me it's either Jesel or stockers
Old Nov 16, 2011 | 07:16 PM
westtexasbuff's Avatar
Stock rockers with trunion upgrade.
Old Nov 16, 2011 | 09:02 PM
AFASTYZFR1's Avatar
I haven't had any problems with stock ones
Old Nov 17, 2011 | 10:03 AM
pdasterly's Avatar
same here
Old Nov 17, 2011 | 10:57 AM
gnx7's Avatar
AtomicFusion (turbo Vette) went high 7's with stock rockers/trunion upgrade.
Old Nov 17, 2011 | 11:38 AM
01 blue ss's Avatar
I just looked at all three of his builds on his site and all of them say he had Harland Sharp rockers.
Old Nov 17, 2011 | 06:05 PM
Fbodyjunkie06's Avatar
Trunion upgrade, you won't find a lighter rocker than the stock ones.
Old Nov 17, 2011 | 07:33 PM
turbo6man's Avatar
Default Rockers
Where is the best vendor/price to get the trunion upgrade?
Old Nov 18, 2011 | 07:57 AM
01 blue ss's Avatar
Everybody has them for around $139 but you can maybe do a google search on them and price match them thru somebody. TSP has them already done with the upgrade for $399.
Old Nov 18, 2011 | 11:21 AM
noonzor's Avatar
dont mean to thread jack, but im looking to do this aswell but for 317's, been looking at these.....http://www.summitracing.com/parts/CCA-13702-KIT/
Old Nov 18, 2011 | 11:31 AM
Rickys S/C Z28's Avatar
what is Trunion upgrade?
Old Nov 18, 2011 | 12:30 PM
TermnEatr's Avatar
X2 on stock with trunion kit... Converts stock to a enclosed roller trunion.. Stiffer More Durable 8620 Steel Alloy Material... Caged Roller Bearings ....Designed For Circle Track/Drag Racing Performance-Proven Tested In NASCAR GM LS Spec Engine Series. A must do upgrade if working with stock rockers and high hp-rpms.
Old Nov 18, 2011 | 01:07 PM
MIGHTYMOUSE's Avatar
when do you need this fancy trunion upgrade? is it something i should look into?
Old Nov 18, 2011 | 01:52 PM
lmt0705's Avatar
LOL! thats funny ****, if you do it youll be in the 7s! i guess it would be good piece of mind though
Old Nov 18, 2011 | 01:58 PM
87silverbullet's Avatar
I know you're playing, right? Riiiiiggghhhhhttttt
Old Nov 18, 2011 | 02:05 PM
TermnEatr's Avatar
You better hurry!!
Old Nov 18, 2011 | 03:11 PM
98Z28CobraKiller's Avatar
Restricted User
I've been running the same stock stock rockers for years on various different set ups and that's one thing that has never given me a problem.
Old Nov 18, 2011 | 03:32 PM
I_Need_Land's Avatar
stock with the comp trunion here.
i have personally seen an oil change with needle bearings in it. not worth the risk to me, 140 bucks now, 7000 engine later...
