New PB..6.0@116mph....9.6@126mph video!
Old 05-08-2012, 09:20 PM
  #121
LSXFORMULA99's Avatar
Rule 2000 is wired, should have the fittings on the tank and all the hose finished this week..getting close
Old 05-26-2012, 06:38 PM
  #122
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
  #123
[IMG][/IMG]
Old 05-26-2012, 06:39 PM
  #124
took the vette out for a cruise[IMG][/IMG]
Old 05-27-2012, 07:35 PM
  #125
my tuner is really busy right now but i hope to have some dyno numbers and video in a week or so...
not sure what kind of boost it will make with the little yellow spring, we will see
Old 05-28-2012, 06:49 PM
  #126
dragonkrs's Avatar
Nice T/A
Old 05-30-2012, 09:40 PM
  #127
I have been looking at other builds and guys with stock cubes and smaller turbos are going into the 9s. I hope my combo works as well as them
Old 05-31-2012, 12:28 AM
  #128
Fbodyjunkie06's Avatar
I think your goal will be easily achieveable.
Old 05-31-2012, 06:26 AM
  #129
1fast bird's Avatar
If it doesn't easily go 9's, then I would say traction is the issue. Definately should make the power to meet your goals.
Old 05-31-2012, 01:19 PM
  #130
nice. its going to need some suspension work. i have stock shocks on front and back
Old 05-31-2012, 01:25 PM
  #131
Then what you need is a good set of shocks.
I would do strange double adjustables or afco's if you can swing the price for the Afco's.
I have Afco DA's coil overs at all 4 corners and I wouldn't trade them for a big block They are the sole reason my car hooks at the track every time I run it.
Old 05-31-2012, 01:28 PM
  #132
What springs are you running
Old 05-31-2012, 01:29 PM
  #133
Well my car is very light. 3000lbs raceweight, but they are afco springs and they are 150# in the rear and 275# in the front.
Old 05-31-2012, 01:32 PM
  #134
Damn that's light. I'm going to have to take some weight out also. I'm probably close to 3700 with me lol...
Old 05-31-2012, 06:48 PM
  #135
L92 fox's Avatar
Ive heard great things about the strange DA coil overs, that's why I have them on all the corners. If you don't wanna drop a grand on coil overs, look into an adjustable shock for the from and rear, drag springs in the front an stock springs in the rear.
Old 05-31-2012, 06:53 PM
  #136
Yeah I will probably put coil overs on the front for now and see how it does. How much did u pay?
Old 05-31-2012, 07:04 PM
  #137
Corey (l92fox) what springs are on the front of your car
Old 06-02-2012, 09:26 PM
  #138
What lb springs are people running on their strange struts?
Old 06-03-2012, 01:23 PM
  #139
I have always heard if it was full weight 325 in the front, medium amount of weight reduction(3200-3400lbs raceweight) 300 in the front. For really light vehicles a 275 like I run in the front is probably best. I like having a taller softer spring in the front on a lower power car as it stores more energy and during launch stored energy helps transfer weight a lot better than a heavier, shorter, stiffer spring.
Old 06-03-2012, 04:46 PM
  #140
samdogmx's Avatar
whos doing the tune? lowe perf?
Quick Reply: New PB..6.0@116mph....9.6@126mph video!
