Vertical Radiator Fan Average CFM rating
Next year when my car goes back together it will have about 4400 CFM of fan blowing though the radiator to make it live in the summer
Also, were you running the turbo with the fan set-up you described?
I now have 2 pushers no shroud. one flows 2200cfm by itself and the other does 1100cfm. But fall hit by then. Car run MUCH cooler now.
i tried a single larger pusher fan with no shroud at first, and it would overheat. I think it was only 1600 cfm though.
what aslo helped was this little piece of metal i put in front of the new core support.
