Good bye Twins hello Single front mount!!!!!!
Old Nov 29, 2011 | 02:45 PM
  #61
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by Nitroused383
I don't see an 87mm turbine wheel fully supporting a 82mm billet compressor wheel.
The billet 82 flows 126lbs/min with the large 96mm turbine wheel. The 87mm turbine wheel limits the turbo down to ~115lbs/min.
Old Nov 29, 2011 | 02:50 PM
  #62
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by tomz28
talk to my turbo guy today they just made 1067rwhp with one of there older 80mm turbos. there putting something like i got on soon. shooting for 1200whp. its on a ford 408. so things look good as far as power goes.
Sounds like they need to find a new dyno. No dis-respect, but we sell the same turbo since it comes direct from BW. That turbo supports around 115lbs/min MAX with the 87mm turbine wheel. The comp map BW uses is based on the larger 96mm turbine wheel and 1.32A/R housing coupled with that wheel. And to make 1200rwhp you would need about 145lbs/min of air and ~69lbs/min of turbine flow, which the BEST 87mm turbine wheel is done at 45-47lbs/min . A GT55-91 is hanging its tongue out at that lbs/min on that big of a motor. Adverting can not cheat physics.
Old Nov 29, 2011 | 03:16 PM
  #63
mike13's Avatar
what about the 92 wheel?
Old Nov 29, 2011 | 03:19 PM
  #64
DrTurbo's Avatar
LS1TECH Sponsor
The 92mm turbine wheel can support the power as it flows ~60lbs/min. Which will support right at 130lbs/min of compressor wheel flow.
Old Nov 29, 2011 | 09:15 PM
  #65
tomz28's Avatar
Jose do you have any flow charts for the different wheels. That would be great
Thanks
Old Nov 30, 2011 | 10:37 AM
  #66
DrTurbo's Avatar
LS1TECH Sponsor
Thanks
Sure do....but they are the proprietary maps from BW. So they can not be publicly posted. Give us a shout, we can get you all the info you want as far as flow, PR, S-rpms and Eff% of the wheels.
Old Nov 30, 2011 | 11:07 AM
  #67
DrTurbo's Avatar
LS1TECH Sponsor
Here is the billet 82mm public map. Keep in mind that comp wheel flow is WITH the larger 96mm 1.32A/R combo. That comp wheel was originally a KKK part #.
Map is attached.... That is .952 kg/s of flow or 126lbs/min. Or about 1260hp crank WITH the big turbine wheel. The smaller 87mm tuibine wheel limits the flow to about 115lbs/min
Attached Thumbnails Good bye Twins hello Single front mount!!!!!!-110s75.jpg
Old Nov 30, 2011 | 01:46 PM
  #68
tomz28's Avatar
I guess Seth said this is a new turbine wheel. Any info on this. I've been doing alot of reading on turbos. Just trying to learn as much as I can
Old Nov 30, 2011 | 01:55 PM
  #69
DrTurbo's Avatar
LS1TECH Sponsor
Flows about ~1-2lbs more then the 783 turbine. We have the new 87 turbine available.....they are slightly different radius and taller tip height from what I remember. Hub thickness is still the same. Great turbine wheel, but no where near big enough to support 1200rwhp. 1000rwhp is a stretch on a V8 with a true dyno.
Old Nov 30, 2011 | 02:30 PM
  #70
tomz28's Avatar
Good to know thanks for the info on its power output. Now how do you feel about how fast it will spool on a 402?
Old Nov 30, 2011 | 02:48 PM
  #71
DrTurbo's Avatar
LS1TECH Sponsor
Spool REAL fast
Old Nov 30, 2011 | 03:02 PM
  #72
mike13's Avatar
If I understand correctly it takes a 92-94mm turbine wheel to get the full benefit of a 82-83mm billet comp wheel in this series of turbo?
Old Nov 30, 2011 | 03:03 PM
  #73
DrTurbo's Avatar
LS1TECH Sponsor
Yes sir it does. The 83mm flows ~130lbs/min.
Old Nov 30, 2011 | 03:08 PM
  #74
tomz28's Avatar
Right on. So my goal is 9 flat, can we do it with this turbo
Its a 402 with TF 225 heads and 4l80. You can see my old times in my sig. those times are with my old 364cid engine on low boost
Old Nov 30, 2011 | 03:11 PM
  #75
mike13's Avatar
If your looking for those kind of numbers I would talk to FI about the GT91 they build.
Old Nov 30, 2011 | 03:17 PM
  #76
tomz28's Avatar
I did tell Reed I would max this turbo from him lol. Its shouldn't be to hard by the sounds of it lol
Old Nov 30, 2011 | 08:08 PM
  #77
DrTurbo's Avatar
LS1TECH Sponsor
Yes 9's can be done. You will run out of turbine side will be your limitation. LS heads just flow a ton of air and the turbines are the ones that are limiting most setups. The new GT91 with the new optional 97mm turbine wheel from testing picked up 75rwhp on a customers setup with nothing else changed. This was at the same boost levels too.
Old Nov 30, 2011 | 08:24 PM
  #78
mike13's Avatar
A GT91 with a 97mm turbine, I wish you guys made this in a divided housing,
Old Nov 30, 2011 | 09:09 PM
  #79
DrTurbo's Avatar
LS1TECH Sponsor
Then check the S91. The BW based unit uses the same basic setup. 91mm wheel with 96mm turbine wheel and 1.32A/R divided housing.
Old Nov 30, 2011 | 09:37 PM
  #80
trans2000am's Avatar
tom are u using truck manifolds or custom headers?
