Good bye Twins hello Single front mount!!!!!!
Old Nov 26, 2011 | 08:53 PM
  #41
tomz28's Avatar
which rad for 1200chp? or more lol
Old Nov 26, 2011 | 09:24 PM
  #42
MUSTANGBRKR02's Avatar
I would cut the flanges and weld v-bands. If you are really crafty then cut the passenger manifold and weld a straight pipe to the manifold then to a v-band to make a easy route for the down pipe to fit thru.
Old Nov 26, 2011 | 11:33 PM
  #43
Texhotrod593's Avatar
If you are wondering which of the Griffen Radiators will do this technically none if the 3 will do it BUT there are a few that have got away with the gri-1-25241-x
But I would personally dish the extra 100 bucks out and go for the gri-1-55241-x or gri-1-55241-xs.
Old Nov 27, 2011 | 01:02 PM
  #44
tomz28's Avatar
good info guys thanks
Old Nov 28, 2011 | 10:44 AM
  #45
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by mike13
It's funny because if you look at the number cast on the housing it's the same, they must of machined my cover. Yep lot's of turbos, I've run all 3, the 80/87 is the one I just took off, it was out of air at 12lb's, it was pushing some serious air but it was maxed. I don't know the horsepower but my 80lb injectors where at 77% duty cycle @70psi fuel pressure. 5100rpm.
Mike the air horn is not an air horn, its called a Noise attenuator. Simply there to reduce noise. Also the 83mm billet wheel has a larger exducer then the 82mm billet wheel so it will support more pressure and more power....by around 3 lbs/min or ~30hp. Also the smaller 87mm turbine will fall flat on a rear mount compared to the new 92mm LDP turbine you have. So the units are quite different then what he was sold.
Old Nov 28, 2011 | 11:14 AM
  #46
mike13's Avatar
http://www.youtube.com/watch?v=iW6X9hDYHY4
583@10lb's my run is at the 2:00 minute mark, as you can see it spins the rollers pretty hard. it spun the tires on the dyno so the power stayed flat from 5100rpm on
Old Nov 28, 2011 | 11:49 AM
  #47
ws602's Avatar
This is what i had Ron Davis make me
Old Nov 28, 2011 | 01:14 PM
  #48
tomz28's Avatar
So Jose how do you think my turbo will work on my set up than?
Old Nov 28, 2011 | 01:15 PM
  #49
tomz28's Avatar
Mike 13 what trans do you have in your car?
Old Nov 28, 2011 | 01:19 PM
  #50
mike13's Avatar
4L80E, 3600 stall w/transbrake
Old Nov 28, 2011 | 01:21 PM
  #51
tomz28's Avatar
hell yes that is a good number than. unlocked? and what kind of conveter and dyno/
thanks man
Old Nov 28, 2011 | 02:32 PM
  #52
mike13's Avatar
thanks man
Yes unlocked, Mustang dyno, the 583 was at 5200 rpm, the tires started to slip and the power stayed level to 6200.
It's a Jake's 4L80E with a Torque Converter shop billet converter that came as a package from Jake's.
Old Nov 28, 2011 | 03:16 PM
  #53
Nitroused383's Avatar
I don't see an 87mm turbine wheel fully supporting a 82mm billet compressor wheel.
Old Nov 28, 2011 | 06:51 PM
  #54
tomz28's Avatar
well the only thing i can do is hope that the guy who happens to do this for a living, that has alot of fast cars running his turbos hasnt done me wrong
does anyone know who JR gibson is? lol
http://www.workturbochargers.com/customers.html
Old Nov 28, 2011 | 08:02 PM
  #55
mike13's Avatar
If it doesn't work he can always machine it for a different wheel, it will at least help you decide what your looking for as far as balance between hp & spool.
Old Nov 28, 2011 | 08:12 PM
  #56
tomz28's Avatar
true but as long as it spool fast that's the most important to me right now.
Old Nov 28, 2011 | 08:27 PM
  #57
Sluggish's Avatar
Originally Posted by craig382ci
I would talk to Josh on making you up some custom headers. I leave that stuff in the hands of a pro.
Non-sense, you never know what you can do until to try it, headers really aren't that hard just a little time consuming.
Old Nov 29, 2011 | 05:59 AM
  #58
Rickys S/C Z28's Avatar
i think it will spool fast...just not as fast as the twins
Old Nov 29, 2011 | 09:21 AM
  #59
tomz28's Avatar
spool fast for a large single is what i should say. nothing is going to spool like the twins lol
but i should be easier for me to make the car come out of the hole.
the single should also free up some pounds. those twins are heavy. the intercooler is heavy as hell too with huge cast end tanks. i bet its 40lbs lol
Old Nov 29, 2011 | 02:39 PM
  #60
tomz28's Avatar
talk to my turbo guy today they just made 1067rwhp with one of there older 80mm turbos. there putting something like i got on soon. shooting for 1200whp. its on a ford 408. so things look good as far as power goes.
