Good bye Twins hello Single front mount!!!!!!
Old Nov 24, 2011 | 09:42 PM
tomz28's Avatar
Default Good bye Twins hello Single front mount!!!!!!
well after doing alot of thinking. and looking at all the bad *** front mount setups. ive made up my mind and im goingto build a single setup. hoping for 9 flats
got a few teaser pics for you guys
the turbo is a BW400SX3 82mm billet wheel. T6 1.10ar. rated hp is 1300.
also picked up a 60mm tial WG and BOV
enjoy
Old Nov 24, 2011 | 10:15 PM
mike13's Avatar
I just picked up a 83mm billet comp/ 92mm turbine turbo from Forced Inductionss.
Old Nov 24, 2011 | 10:22 PM
tomz28's Avatar
what did you pay for it if you dont mine me asking?
what kind of turbo is it?
race cover?
Old Nov 24, 2011 | 10:25 PM
mike13's Avatar
Borg Warner, race cover.
Old Nov 24, 2011 | 10:38 PM
mike13's Avatar
[IMG][IMG][/IMG][/IMG]
Old Nov 24, 2011 | 10:40 PM
mike13's Avatar
One on the left is the new 83mm, the other two are a 80mm/83turbine and a 80mm/87mm turbine
Old Nov 24, 2011 | 10:41 PM
mike13's Avatar
Old Nov 24, 2011 | 10:45 PM
tomz28's Avatar
mine has a air horn if thats what you want to call it in the compressor cover. but be sides that they look the same. you got alot of turbos lol.
Old Nov 24, 2011 | 10:53 PM
mike13's Avatar
It's funny because if you look at the number cast on the housing it's the same, they must of machined my cover. Yep lot's of turbos, I've run all 3, the 80/87 is the one I just took off, it was out of air at 12lb's, it was pushing some serious air but it was maxed. I don't know the horsepower but my 80lb injectors where at 77% duty cycle @70psi fuel pressure. 5100rpm.
Old Nov 24, 2011 | 10:58 PM
cracker's Avatar
Originally Posted by Bloodbath
sweet dude, that turbine wheel looks soo good.
That's a compressor wheel homie. Turbine typically refers to the exhaust side.
Old Nov 24, 2011 | 11:00 PM
tomz28's Avatar
i saw that to lol. you can see that ridge on the inside of the cover on yours. i bet that air horm sits on that. my air horn has 3 roll pins holding it in.
why do you say the turbo was max at 12psi?
Old Nov 24, 2011 | 11:01 PM
tomz28's Avatar
i saw that lol. i was just going to let it slide lmao
Old Nov 24, 2011 | 11:16 PM
mike13's Avatar
I had a 18lb spring and would only see 12lb's and according to the injector calculator it was about 1100chp.
Old Nov 24, 2011 | 11:44 PM
mr_biscuitz's Avatar
Where did you buy that cover for your air filter on the pass side valve cover or if you made it how? Thanks
Old Nov 25, 2011 | 03:13 AM
Rickys S/C Z28's Avatar
looks good tom
Old Nov 25, 2011 | 07:48 AM
tomz28's Avatar
its just like any other beather. but it has a sweat band around it to stop it from misting everything in oil
Old Nov 25, 2011 | 07:49 AM
tomz28's Avatar
Originally Posted by Rickys S/C Z28
looks good tom
Thanks ricky
Old Nov 25, 2011 | 09:39 AM
TheLS1Lover's Avatar
Looks good, going with Truck Manifolds or Custom Headers?
Old Nov 25, 2011 | 11:14 AM
MUSTANGBRKR02's Avatar
Looks awesome.
Heck if you could pm me what you paid for that Tom. Thanks.
Old Nov 25, 2011 | 09:53 PM
tomz28's Avatar
well a friend and i are working on a trade. Might get some OFI headers and a crossover. but if that dosent work. i just got some manifolds for back up.
