Good bye Twins hello Single front mount!!!!!!
that im more than able to make my own setup. im not worried about maybe having to redo something or making a mistake i bet Josh had alot of that when he started out. cant wait to see your car done by the way
Reed was telling me that he has a guy with a mustang with a 40X cid engine and it goes low 9s on something retard like 10psi.
and a guy with a 4500lb sivlerado that goes 10.1X on 13psi. so hes got good feedback on this turbo we just need to get it in the car now lol
The breather filter you have on the driver valve cover, is the arm band on there to stop the little oil that drips out after making a few runs.
I was thinking about doing the same thing
truck manifold flanges to weld the hotside to
T6 flange
what kind of griffin rad to use
some pics of stood up rad would be great.
Stainless T6 Flange - http://www.mandrel-bends.com/catalog...ange-1032.html
Mild T6 Flange - http://www.mandrel-bends.com/catalog...steel-264.html
Stainless Truck Manifold Flanges - http://www.mandrel-bends.com/catalog...lange-637.html
Mild Truck Manifold Flanges - http://www.mandrel-bends.com/catalog...lange-639.html
Thank you sir. Are you doing Mild or SS?
Yea that radiator does not come with a steam port, people either tap a bung or weld in a bung with a barb fitting and ur done. Either way u look at it this general purpose radiator for $180 is still a lot cheaper then $600 for a stock replacement and a ton of people use it with excellent results. BUT again to each there own...
I wouldnt use the gri-1-25241-x if I was you unless it was most def I wasnt going to be using a/c and also keeping my HP below around 600. I recommend 1-55241-x or 55241-xs
here is a link to my findings on griffen rads. see page 15 post #282...
https://ls1tech.com/forums/forced-in...e-here-15.html
__________________
