Good bye Twins hello Single front mount!!!!!!
Old Jan 11, 2012 | 12:21 PM
  #221
eviltwin_1987's Avatar
Would a straight one fix your problem?
Old Jan 11, 2012 | 02:05 PM
  #222
tomz28's Avatar
It might. Now where do I find one?
Old Jan 11, 2012 | 02:22 PM
  #223
bad6as's Avatar
You could flip it 180* too. But some one makes a nice aliminum one my friend had one but I don't remember the brand
Old Jan 11, 2012 | 02:24 PM
  #224
http://www.jegs.com/i/CSR/170/911LS1C/10002/-1
Old Jan 11, 2012 | 02:25 PM
  #225
I hear this one works too
http://www.rockauto.com/catalog/raca...4-33939-283018
Old Jan 11, 2012 | 02:32 PM
  #226
95lt1z383's Avatar
I picked mine up from summit along with the ls2 160 t stat. I used the one made by csr worked out great.
Old Jan 11, 2012 | 03:39 PM
  #227
tomz28's Avatar
You guys are ******* awesome, its like having a R&D team at my finger tips lol. This will make my life way easier
Old Jan 11, 2012 | 04:56 PM
  #228
Chubbz155's Avatar
Yea these guys are awesome!
Old Jan 11, 2012 | 07:30 PM
  #229
95lt1z383's Avatar
You will have to do a small amount of grinding on the inside of the csr housing to get it to clear the thermostat and bolt up flat. Nothing crazy just the inside of the housing is to small for the top of the ls2 thermostat that you will need to keep your heat working right.
Old Jan 11, 2012 | 07:56 PM
  #230
95lt1z383's Avatar
Also if you are going to use the griffin radiator you can try what I did. I set it up as a dual pass setup with both inlet and outlet on the driver side. It helps with cooling and makes the radiator hose layout a snap. Just use stainless tubing to make your hoses and your good to go.
Old Jan 11, 2012 | 08:06 PM
  #231
tomz28's Avatar
I was thinking of something like that.how well does it cool?
And do you have any pics?
Old Jan 11, 2012 | 08:30 PM
  #232
Taubr Unit's Avatar
Awesome turbo placement!! Glad your doin my dirty work on how to mount it when I get around to mine, lol. Lookin good!!
Old Jan 11, 2012 | 08:42 PM
  #233
95lt1z383's Avatar
I have a single 17 inch fan and the temp stays around 190 most of the time. Even after a few hard boosted runs on the street it will cool off quick. I can take a pic for you tomorrow. All you need to do is move the inlet and outlet to the side you want. Then cut a slot in the tank between the tubes and weld in a plate to divide the tank into two parts.
I have a pic of my old setup its the same just the inlet and outlet on on the other side.
Attached Thumbnails Good bye Twins hello Single front mount!!!!!!-pics031.jpg
Old Jan 11, 2012 | 08:55 PM
  #234
tomz28's Avatar
Im on the same page for sure. No kiddingI was thinking of doing this.can't wait to see some more pics
Old Jan 11, 2012 | 09:10 PM
  #235
tomz28's Avatar
Your welcome it only took about 4 hours to figure out the perfect angle lol
Old Jan 12, 2012 | 01:26 PM
  #236
tomz28's Avatar
My work station
How much I trimmed the driver side manifold
Something like this is what I was thinking
Old Jan 12, 2012 | 01:35 PM
  #237
bad6as's Avatar
Could you go under the alt and under the oil pan?
Old Jan 12, 2012 | 01:45 PM
  #238
tomz28's Avatar
I don't see why not
Old Jan 13, 2012 | 01:13 AM
  #239
Fbodyjunkie06's Avatar
Man you ain't got this thing done yet?!?! Hurry up dammit!!!
Old Jan 13, 2012 | 10:09 AM
  #240
Hugger Z's Avatar
Progress is looking awesome man!
