Time to talk about new motors....Bigger ones!
i am not sure if i need to drill through the hub at the provided keyway path that ATI provided...or drill a new path thru the hub....i am also unsure as to whether or not i should install the jig directly to the crank snout and drill it that way and then line the hub up afterwards...basically i have no idea how to do it. and its been holding up my install for 5 days. use this video as reference. http://www.youtube.com/watch?v=W5E5Vavbp7E this is my rough draft video for making sure noone ever has this problem again.
Install the supplied harmonic balancer pinning tool using the supplied M16 hex
bolt.
Tighten the bolt to hold the tool in place and prevent spinning during the drilling process.
Using the supplied 1/4” HSS drill bit, drill a hole in the crankshaft/harmonic balancer 0.800” deep from the face of the crankshaft. The hole will be centered on the O.D. of the crankshaft. Do not drill deeper than 0.800”. Remove the pinning tool and set aside.
Using compressed air, blow out the hole to insure no chips or debris are present.
Install the supplied 1/4” O.D. x 0.750” long stainless steel dowel pin in the hole.
Install a new factory M16 bolt and torque to 40 ft-lbs plus an additional 120º of rotation.
Attach the supplied 8-rib crank pulley to the aftermarket damper using the
supplied 3/8-24 x 1.5” hex bolts and lock washers. Be sure to apply thread locker to bolts before installation.
Torque the three 3/8” bolts to 40 ft-lbs. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Very possible on the blower. Not sure when I'm going to start ordering parts for it. Need to figure out engine builders as I'm going to be away for awhile lol. Tom...the budget is pretty decent.....anything on BB?
#36
This is very rapidly turning into something crazier then I planned lol. The subject of F2's deff came up. One of my main concerns is that the car see's major street duty and I need to keep that in mind.
