Truck manifold wastegate sources
Wrapping up my turbo 4.8 build and I'm just trying to figure out the best places to get the wastegate and bov vacuum/pressure sources. My main question is, is it safe to T off the line that goes from the top of the throttle body to the passenger side valve cover for the wastegate?
Is it also ok to T off the line that goes from the top of the intake to the back of the driver side valve cover?
If there are better places for these sources, let me know. I already have my electronic boost controller pressure sensor and boost gauge running off that port about 3/4 of the way back on the passenger side of the intake that you can cut off for a pressure/vacuum source.
Any advice will be appreciated
