Gt4788
Old Jan 11, 2012 | 05:03 AM
  #101
JLE58's Avatar
Is the gt5091 comparable in size for limited space?
Old Jan 11, 2012 | 08:02 AM
  #102
craig382ci's Avatar
Originally Posted by black98ws6ta
PTE once rebuild a t4 88 for me like 5 times before we came to the mutual agreement that it was being over spun, pushed too hard, and failing. Alot of times there are fine lines to where a combo is happy or not and right or not and sometimes hard to get there without a long talk about a combination. Then there are people who have been there and done that and post up the results and nobody listens. I cant count how many times Dr turbo has posted that the 47-88 is too small for the larger ls crowd. I also posted my thoughts in this thread and I have a 47-88 on a 5.3l....which should be on the happier side of displacement for that turbo.
Ok so in you on opinion. What would be the right turbo for a 408ci and a 410ci?
Old Jan 11, 2012 | 08:13 AM
  #103
craig382ci's Avatar
But I still don't understand why both Percision and Garrett would tell me to stick with the 4788. And yet this 4788 seems to be a big issue. Not just on this thread but many others. But talk to the ppl that make turbos like stated above and they are know issue. Then you see someone like tinkerd with a 408ci do as well as he done. Makes someone like me an konceptracin somewhat confused.
Old Jan 11, 2012 | 08:37 AM
  #104
bad6as's Avatar
You need a hp number to aim for.
Old Jan 11, 2012 | 08:42 AM
  #105
craig382ci's Avatar
I have one 1100 to 1200hp ET mid to high 8's
Old Jan 11, 2012 | 08:43 AM
  #106
craig382ci's Avatar
read post 99
Old Jan 11, 2012 | 08:45 AM
  #107
bad6as's Avatar
Wheel or flywheel
Old Jan 11, 2012 | 08:47 AM
  #108
craig382ci's Avatar
Wheel or flywheel
wheel
Old Jan 11, 2012 | 09:01 AM
  #109
bad6as's Avatar
1200 wheel ill assume threw an auto. you talking about about 1400 fly wheel. with 400+ci your bp will be very high on the gt4788 turbine. were you limited to a 88mm?
Old Jan 11, 2012 | 09:18 AM
  #110
craig382ci's Avatar
Yes on the A4 and no on being limited to a 88mm. I bought the 4788 bb and based the rest of my build around it. Fraser at AES based my CI on the turbo and my goals. Which is how I ended up with the 410ci. I had also spoke to Shawn at ERL before I spoke to Fraser at AES and he was going to do a LS6 427ci with my 4788 T6 A/R 1.23 bb turbo.
Old Jan 11, 2012 | 09:30 AM
  #111
bad6as's Avatar
A lot of the 1200whp cars I see with that turbo are sbf and supras. The ls motors flow a lot of air compared to older sbf and sbc. I know it suckcs that you bought a nice turbo and built your combo around it but I think you will choak it. I had a 80mm that I was told would do 1100 flywheel. Well even after going from a 1.10 ar to a 1.25 and from a 83mm to 87mm turbine its still choaked out. 13 lbs boost was just under 1.5 back pressure and I'm a 9.0 compression 365. Now I'm redoing my whole turbo kit with a new turbo. I thought about the gt4788 and I still may do it if I find a deal on one. But if you want 1200 wheel then ide look in to a 91mm compressor and some thing with a 100mm range turbine
Old Jan 11, 2012 | 09:41 AM
  #112
craig382ci's Avatar
PM sent
Old Jan 11, 2012 | 11:23 AM
  #113
98Z28CobraKiller's Avatar
Restricted User
I only comment on what I know and what I know is that the PT88 is too small for my mild 370 and the GT4788 is very similar. Does it work? Yes. But it's not optimized. I can feel it lay over at about 6K RPM. I got a buddy with a Fox Mustang with a 331ci SBF and he was having the same problem. He got his to 8.6's in the 1/4 at about 300-400 lower raceweight. He recently upgraded to a T4 GT5088 from Forced Inductions. It has the same exact PT88 exhaust housing with it bored out a little to accept the bigger wheel and ran a 8.4 his first time out with a soft 1.34 60'.
So if the Pt88 is too small for my mild 370 street car, then it will only choke a 408 more. Here's the thing though. The 88mm will be enough to overpower the street. It's enough on the 370 and it's certainly going to be enough for a 408 but it's not optimized. What Black mentioned above is the correct way to do a street combo with an 88. The 5.3 or even a 4.8 should be perfect and will be far more reliable.
Old Jan 11, 2012 | 11:26 AM
  #114
Restricted User
My understanding is that the Gt50 turbine wheel goes in the same exhaust hosuings as the Gt47. They are just opened up a little. Maybe Dr.Turbo can chime in. So, yes.
Old Jan 11, 2012 | 11:33 AM
  #115
bad6as's Avatar
what housing does the t6 gt88 share?
  #116
Restricted User
I'll bet that you didn't communicate what you wanted correctly. By that I mean little catch words like "street car", "instant boost", and "no lag" will cause someone to want to error on the conservative side of the turbo.
Old Jan 11, 2012 | 11:41 AM
  #117
craig382ci's Avatar
They asked me what my goals was first and I said about 1200hp to the wheels. ET's around mid to high 8's. They asked me is this a street/track car. I said yes. They said more street than track or more track than street. I said 70% street and 30% track. They asked what CI. I told them 410.
Old Jan 11, 2012 | 11:43 AM
  #118
craig382ci's Avatar
I told them that I didn't want it to be to lagy
Old Jan 11, 2012 | 12:08 PM
  #119
Restricted User
Wow, well atleast they were all consistent in missing the mark. Sucks.
Old Jan 11, 2012 | 12:14 PM
  #120
konceptracin's Avatar
What a/r can u suggest for the 91.5 infact what is the difference between the 91 and 91.5? Any one know? I would rather have more room to grow in a bigger turbo instead of needing to buy a new one ... But def don't want the car to fall on it's face or feel like it's dying out after 6k
