need help picking turbo parts
:manifolds
i will be making some custom sch10 tubular manifolds.
:wastgate
pt46mm x2
:turbo
this will be a street car so i dont want to go to big here and give up spool for over all power.needs to be v-band in/out (only avl. in .63 or .82) the 3 turbos i have in mind are the billit. 5857,6057 and the 6262.
:12 volt oil pump
i know the turbos will be to low to just drain back to the pan with out some sort of pump. i have no idea what will work best here
:fuel (e85)
i alredy have 2 bosh 044 fuel pumps, sump for the stock tank,-8an feed line, and fuel lab 100 psi base regulator.
:injectors
i have 4 fic 2150cc injectors. should i just buy 4 more (750$) or sell the ones i have and get 8 smaller fic injectors?
:tranny
stock/rebuilt t56 with billit keys 1-6, steel 3-4 fork and brass shift pads 1-6
:clutch
rxt twin/steel flywheel combo
well thats my plan, any and all help would be appreciated.
-Alex d
A pair of 5858 CEA ball bearing would kick ***. (.63 v-band)
I don't think the 5558's would have any better response. (at least they didn't before the CEA turbine wheels, 5557 vs 5857)
