Unleashed Performance - 810RWHP, Stock Engine, Oil-less Rear Mount, and E85
Old 03-19-2012, 10:49 AM
  #121
96TransAmboosted's Avatar
Just wicked sick work, now I will be replacing my garrett with a comp. Love the paint.
Old 03-31-2012, 02:05 AM
  #122
nubs4ck's Avatar
Have you put it on the dyno with the air filter in place, or was it removed? Just curious how much of a restriction the filter actually is at over 800whp.
Another question I have is what A/R is the exhaust housing that you used?
Old 04-10-2012, 04:49 PM
  #123
Blevinator's Avatar
I would like to know the A/R as well. I am looking at the 76mm Comp Oilless and am told .81 is good for rear mount. Others say it will choke on top end and I need .96. Please share with us what you used!
Old 04-10-2012, 09:24 PM
  #124
SPRAYED 01's Avatar
Do at least .96. Their triple ball bearing spools super fast. If there is one thing you ever listen to make it be this, get a .96 or larger. I run a 1.32 and I don't know what lag is on my comp 80/79
Old 04-10-2012, 10:30 PM
  #125
Blevinator's Avatar
You suggest .96 on a rear mount?
Old 04-11-2012, 09:08 AM
  #126
SPRAYED 01's Avatar
Yes even larger. These turbos should not be Compared to normal journal bearing turbos. You would be surprised how quick they spool.
Old 04-11-2012, 11:06 PM
  #127
Unleashed-Performance's Avatar
We have never even tried running the car without an air filter. It has always had a K&N cone filter in place. But now you've got me curious about trying it on the dyno soon.
Regarding the A/R of the turbo, we are using the .96 housing. I chose this because of the car being an M6, thinking it would help it spool faster. But as several people have already mentioned in this thread, the Comp oil-less turbo spools much quicker than a journal bearing turbo. So I'm also curious how a larger exhaust housing would work. But seeing as how we just made 840whp tonight, I doubt I'll be changing it anytime soon.
New thread with 840whp dyno graph located here:
https://ls1tech.com/forums/forced-in...-turbo-c5.html
Old 05-02-2012, 09:35 AM
  #128
WS6 GreeN's Avatar
Rob, how did you run your coolant lines to get flow through the turbo? Awesome setup! I love my Comps but I think I have too much turbo and not enough motor now. Also I noticed on the oil-less, when you first get them they are super tight. How long did it take to loosen yours up?
Old 05-04-2012, 03:13 PM
  #129
slick99's Avatar
Up for info on how the coolant lines are run. Inspiring build for sure!
Old 05-04-2012, 03:28 PM
  #130
SPRAYED 01's Avatar
I run a comp water cooled turbo. The coolant lines are easy. I just went from the from steam vent that go to the radiator. Redirected it to the turbo then from turbo to radiator. I just used barb fittings and hose clamps. No issues at all about 4,000 miles.
Old 05-21-2012, 05:41 PM
  #131
TurboAv's Avatar
Want to do a C6? My only concern is the need for water cooling. What was you solution for that? A stand alone setup or lines from the front of the car?
Old 05-21-2012, 07:34 PM
  #132
gs462's Avatar
Do you sell this setup?
Old 05-21-2012, 09:36 PM
  #133
Hank Peabody's Avatar
Being at full boost at 3800rpm, shouldn't the torque around 4000-4500rpm be very near peak, not over 200tq down? Good track numbers either way, just wondering how the tq at 4000-4500 is that low for full boost so early.
Quick Reply: Unleashed Performance - 810RWHP, Stock Engine, Oil-less Rear Mount, and E85
