What rods you FI guys using?
Old Mar 18, 2004 | 08:55 AM
turbo's Avatar
Default What rods you FI guys using?
What rods are you FI guys using in your built motors? Im looking for a good set of rods to handle a lot of power...
Thanks
Casey
Old Mar 18, 2004 | 09:04 AM
SuperZ28's Avatar
Lunati 6.125" billet connecting rods....cost just under $1100 if I remember correctly....I was told they are as good as they get.
-Alex
Old Mar 18, 2004 | 09:14 AM
turbo's Avatar
I was looking at those, but is there a cheaper alternative but just as good. Ive seen other cars use eagle in high hp conditions. But just havent heard about eagles ls1 rods.
Thanks Alex
Casey
Old Mar 18, 2004 | 09:18 AM
SuperZ28's Avatar
I looked at both the Crowly rods ($550) and the Lunati pro mod rods ($700) but I was told the Crowly ones are only good to 500rwhp-ish and the pro mods are good to 650rwhp or so....I rather spend the extra money first and not have to back and fix a mess.
I'm sure others who know a bit more will chime in soon
Good luck with your buildup
Old Mar 18, 2004 | 09:24 AM
NA$TY-TA's Avatar
I have Eagle H-Beam's in my motor, but i upgraded my rod bolts to L19's.... Im shooting for 650rwhp. PSJ uses Eagle rods in his motor and hes making 740rwhp i believe.... im sure he will chime in...
Kyle
Old Mar 18, 2004 | 09:34 AM
MIGHTYMOUSE's Avatar
i also have the lunati billet 6 1/8 rods.
Old Mar 18, 2004 | 09:35 AM
smokinHawk's Avatar
im using eagle rods as well
Old Mar 18, 2004 | 10:32 AM
turbo's Avatar
Thanks for your inputs guys.
Casey
Old Mar 18, 2004 | 10:35 AM
stealth's Avatar
Lunati SBC Pro Billet
Old Mar 19, 2004 | 09:42 AM
Whistler's Avatar
Sawzall and Welder Mod
I put in the Eagle H beams too.
Old Mar 19, 2004 | 10:05 AM
Reckless's Avatar
Super Moderator
There are stock rods holding 650rwhp already. I have used Lunati Pro Mods in both FI motors I have built. I'd say they can handle 1000rwhp if tuned properly. Tuning is always the key folks
Old Mar 19, 2004 | 10:19 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Eagle 6.125's with ARP rod bolts.
Old Mar 19, 2004 | 12:00 PM
Crunch's Avatar
Lunati Pro Mod Rods w/ARP Rod Bolts.
Picture Here
Old Mar 19, 2004 | 12:06 PM
BIGBOS's Avatar
Eagles w/ARP bolts
Old Mar 19, 2004 | 12:11 PM
SuperZ28's Avatar
man, if I knew this I coulda saved myself some money
Old Mar 19, 2004 | 12:16 PM
Crunch's Avatar
I agree 100%. Which is why I didn't spend bookoo bucks on rods made out of kryptonite or some ****.
Pro Mods are just fine.
Old Mar 19, 2004 | 12:19 PM
BIGBOS's Avatar
I wouldn't setup a "built" motor w/stock rods though, if your going in there in the first place might as well back it up for the peace of mind.....if you don't plan on pushing it that hard just use some strong rod bolts, those seem to be the major weakness before the actual rod lets go, or in some cases is the cause of the rod letting go.....
Old Mar 19, 2004 | 01:44 PM
Reckless's Avatar
Super Moderator
Didn't mean it was safe Just that Mike Brown's car was running 9.8s @ 136+ pass after pass with a completely stock bottom end. His weight was 3550 pounds. You figure out how much HP is needed to run 138mph trap with 3550 pounds. By my calculations about 725 ponies
Old Mar 19, 2004 | 03:53 PM
Noyzee's Avatar
8 second mod
Stock!
Old Mar 19, 2004 | 11:24 PM
NA$TY-TA's Avatar
Originally Posted by Noyzee
Stock!
But not stock rod bolts correct???? ARP's??
Kyle
