View Poll Results: can it run 5s with the stock cam at 15psi
Voters: 23. You may not vote on this poll
will it run 5s with the stock cam??proven -yes it will
#102
did you all notice any increase in spool time changing from the stock cam?
if you were referring to me on turning it up, I cant just yet. Im having some severe transbrake/electrical issues that need to be addressed first. The 6.014 pass was the ONLY complete pass I made that day. it will probably be a couple of months before I add the boost controller and try to start working up to 15 psi
Does the car shut off? I remember a friends car doing that, would launch and the factory ford ignition switch would shut off, put in a new ignition switch and was fine.
