Got the head off, pics inside.
We all watch our coolant temp, but it's at the front of the driver's side head, but what if we were able to see what the back of the head was reading and it was 30, 40 even 50 degrees hotter?
You read about lots of NA guys losing #7 ringland, it tells you something.
wouldn't that give you the reading that you are after?
Like you said secondly, steam vents should be there all the time. Especially boosted. I really like that KUP set-up it just looks bad *** like everything KUP does.
In general if you were going to rig up something to measure the heat of the rear cylinders and go through the time and trouble why not just rig up steam vents themselves and be done with it? Or use the stock ones? **** I'm wondering if my car even has them now.
Some people have said that too rich can be just as bad as too lean, why I'm not really sure. When I started tuning, I added a lot of extra fuel to make sure I didn't go lean, and I then started slowly pulling fuel out. When I first started running, it was bottoming out the wideband at less than 10.0:1 and I actually fouled a sensor.
When I had my car on safe mode my AFR would be 11.1-11.2. Normal mode was 11.4-11.6. Kill mode was 11.9-12.2. 15psi 50/50 93&110 14-16* timing.
