Got the head off, pics inside.
When I had my car on safe mode my AFR would be 11.1-11.2. Normal mode was 11.4-11.6. Kill mode was 11.9-12.2. 15psi 50/50 93&110 14-16* timing.
And I'm wondering how to connect all 4 steam pipes with the 102?
Personally I'd go for 12-16(max) timing and high 11's for the afr and look at the plugs and see what the heat looks like on the strap and how far down the bend the timing mark is. If your going to run it on a dyno after building the motor this is very easy to do and check.
Like I said before your a smart well informed guy. I know you'll do what it takes to get the most out of your ride.
I was going to do this, and it seems guys are just tapping the "plugged" section of the head, and just tapping 1/8npt to AN or barbed fitting, and then just T off the current feed...very similar to the LS1 style originally from factory.
So, how far do we tap down?
Can I do it with the heads on and just keep grease and oil on the bit to mind shavings?
And I'm not real clear as to where the rear ports flow to? if you look at the block, you can see the open port on the short block on top of pistons up front for coolant I assume, but the same sections of the block are filled in on each side...just hard for me to see where this rear steam port would vent to...
Please clarify and chime in on this...
When I rebuilt mine I just bought a second cross over that is on the front of the motor and put it on the back. Connected the two ends together with the tubing and a T before they go back to the radiator. So far it seems to have been working okay.
I think you detonate, and #7 is usually leanest.
I'm not saying this is a bad idea, but I don't think it is that big of a deal.
