Got the head off, pics inside.
Here's the combustion chamber:
...and there she blows....
A little j-b weld and it'll be alright I'm thinking...
The cylinder walls don't look too bad, but you can feel a slight imperfection in the wall from where the ring was fluttering.
So, as of now, we're going to flip the car around, then it's time to start tearing everything off the motor to get it ready to come out.
I'm hoping the block is good enough to just do a cleanup and rebuild with a set of forged pistons and rods. Time will tell.
Good luck with the rebuild man. I've been watching your recent threads and hope to learn a thing or two. I'm in the same boat, just want a reliable street car making big hp. Although, it's tempting to just boost the stock motor I plan to just do forged pistons and rods and keep the rest of the longblock stock. I want to avoid damaging anything and upgrade the main weakpoints that boost breaks in the stock engine.
Granted, when you make a lot of power, and the tight factory ring gaps end up causing the compression ring to bind, there's not much the stock piston is going to be able to handle. But heat is a major reason why the rings expand and bind (at least that's what I've read).
Soooo on the new build, all four steam ports will be connected and go back to the radiator just like the factory 98-2000's had them.
this is the pipe setup you want, or somthing similar just to vent the rear sides of the head.
Im planning on doing a FI setup with stock cubes. Keep us updated with what you replace parts with because ill end up doing the same thing most likely so I don't have to pull the motor again.
To others, my last thread I made talks about the rear steam vent ports and options.
I read alot of guys doing this and its great but no one seems to mention a rebal. Some guys don't know that this needs to be done. Also, I never hear anybody mention gapless second rings, how many of you guys use them?
I just got another coolant crossover tube and put it on the back of the heads, ran a line under the intake and T'd into the front crossover tube that goes to the water pump
Sleeved
