Turbo Firehawk build up V 3.0 AES 385 and S88
#401
dschmittie1, are you still using the Virginia Speed VTC2 cam in your car? How do you like it? Is there another cam that you think would be better for your CI+heads+turbo size?
Just curious because I am kinda looking around at cams for my 370ci w/AFR 225's, and I am going to be running the same turbo as you. My cam currently is a custom ground by LME. 236/232 - 114LSA .603/.603
I will say my cam is similar to what you have now. 23x/22X 115 62X ish Also this was more ideal for my old 347 combo as I reused it from that build
#415
Just a quick update. 2 weeks until I head to Georgia for the Chevy High performance Nationals at Atlanta Drag way so I was out tonight changing plugs (I haven't changed them since early fall) I was also checking around since I had noticed slight exhaust tick. I found a couple loose exhaust manifold. also setup everything for the new version of HPT.
I am hoping the weather holds out tomorrow and I can head to Cecil for some last min testing and make my first couple passes on a pro tree in prep for the event.
#418
Thanks guys. The big hold up right now is my Dad borrowed my truck today to help move some stuff for my sister and it now looks like I will not see my truck until after 11 tonight and I have a training class tomorrow for work so I will be getting home later and I can't run home over lunch to load like I could on a normal day so I am gonna be rushed tomorrow. I am looking forward to trying out the Protree
