Turbo Firehawk build up V 3.0 AES 385 and S88
Old 05-21-2012, 08:40 PM
  #141
TheLS1Lover's Avatar
Man that IC looks tiny. I would be worried about the Couplers blowing off also. BTW are you going to run a blanket? The Turbo looks CLOSE to the Cold Side!
Other than that nice phucking build!
Old 05-21-2012, 09:11 PM
  #142
dschmittie1's Avatar
Originally Posted by JAX04
Damn Dan, that looks incredible man! Great work! Im uber excited about the pending 8 second passes
Thanks I am ready for that 8 second pass as well
Originally Posted by SKULL
inter-cooler = restriction!!!
nice job. cant wait to see how the car looks and runs when it is done
Me too. The intercooler is staying for now. Not sure that I am ready to ditch it.
Originally Posted by The Alchemist
Looks great Dan. You've done quite a nice job toting the line between form and function. Best of luck with it.
Thanks Brien I was trying had to make things look clean with out going crazy
Originally Posted by BottleFedZ346
Looks good man!
I love the brace you made for the snail!
Thanks
Old 05-21-2012, 09:15 PM
  #143
Thanks. The IC is a CRX racing 32x12x4 unit. It has been used for the last 3 years in my previous Procharger and turbo builds and has seen 15 psi with no issues. I have more pipes welded together with this build than the last 2 and I haven't had any issues blowing off charge pipes. All of my coupler joints have a rolled lip. I will be picking up a turbo blanket as soon as I can. Just hasn't been in the budget yet.
Old 05-21-2012, 09:21 PM
  #144
bad6as's Avatar
i bet i was seeing a huge drop threw my ebay 31x12x4, no ic for me this time.
Old 05-22-2012, 06:32 AM
  #145
1fast bird's Avatar
Awesome progress Dan! Really looking forward to hearing it run.
Old 05-23-2012, 08:29 PM
  #146
Well I got more done over the last 2 night. I got all my coolant hoses and oil drain lines made up. I also finished hooking up 95% of the wire. I have everything wired that I need to start the car. I just need to finish wiring up some stuff for the headlights, wire up the wideband, gauges and Meth controller an it will be all done. I did pull the tune out of the car and made the changes needed for my bigger injectors, Bigger motor, and E85. I hope to hear it fire up for the first time tomorrow.
Old 05-24-2012, 07:45 AM
  #147
Fireball's Avatar
Is it running yet (its tomorrow now )
Old 05-24-2012, 07:51 AM
  #148
Did you even bring yours back to your house yet??
I should have it fired tonight
Old 05-24-2012, 07:54 AM
  #149
Fireball's Avatar
Nope...been finishing my other big project first...
Old 05-24-2012, 01:42 PM
  #150
YAY! Can't wait for vids!
Would you finish your damn pool already! lol.
Old 05-24-2012, 02:42 PM
  #151
Fireball's Avatar
Sorry...it was a pretty major overhaul...should be done by next weekend (weather permitting)...Just need to get the fence up, liner installed and filled up
Old 05-24-2012, 08:45 PM
  #152
Well it lives. I heard it run tonight for the first time in 6 months. I have some tuning hurdles to get over with this being the first time I have tuned anything with a motor larger than stock and fuel other than 93. I did manage to get it warmed up change the oil. I am having an issue with it starting hot. I have alot of work to do on the tune yet and I ran out of time to work on that tonight. I also have alot of work left to just to get the car drivable. But here is a quick pic and video I took.
Old 05-24-2012, 08:59 PM
  #153
1fast bird's Avatar
Nice Dan! That's a damn good sound! Congrats on the hard work paying off!
Old 05-24-2012, 09:29 PM
  #154
98Camarod's Avatar
What are you tuning it with? I may be able to help you out on the hot start.
Old 05-24-2012, 09:51 PM
  #155
Cam72aro's Avatar
Looked like hp tuners in the video.
Old 05-24-2012, 10:44 PM
  #156
1320king's Avatar
Nice build you got there!! if you dont mind me asking, what front tires are those?
Old 05-25-2012, 05:55 AM
  #157
Thanks Chad still lots of hard work left
Yep HP tuners is right. I know I need to work on my start up idle airflow table. I have a config file for working on that as well as my VE table stuff. The one issues I need to work on is since my AEM wide band is still set up in HTP to display in gas stoick and my HTP is seeing my comanded AFR of 9.6xxx it has my VE% error stuff all jacked up.
Thanks they are the MT SR radials
Old 05-25-2012, 06:12 AM
  #158
Fireball's Avatar
Love it....super sleeper with little to no chop at idle!
Old 05-25-2012, 08:53 AM
  #159
White.Lightning's Avatar
From Websters dictionary:
Sleeper (N): Dan's Trans Am
Hahaha
Old 05-25-2012, 09:06 AM
  #160
98Camarod's Avatar
I didn't watch the video. Dan, pm me your email and you can have a copy of my tune. Copy over the startup tables and you should be good to go. I had the same issue and it fixed mine. She starts up every time. Also with your wideband, you can make the transfer function in the scanner and it will log it correctly, despite what's being displayed on the gauge.
Quick Reply: Turbo Firehawk build up V 3.0 AES 385 and S88
