which pully d1
Old Feb 2, 2012 | 11:26 AM
speedfreak2685's Avatar
Default which pully d1
I am picking up my d1 procharger kit and front mount Saturday. It is going on a full bolt on a custom cam 6 speed and 9 inch camaro. What pully do I need to run to end up with roughly 525 or so to the wheels? 8 or 10 pound pully?
Old Feb 2, 2012 | 11:34 AM
dschmittie1's Avatar
Is the engine stock? is the exhaust stock?
The other question is what size crank pulley is the kit coming with?
Old Feb 2, 2012 | 12:03 PM
Need_a_Camaro's Avatar
Stock cubes I'm assuming?
Old Feb 2, 2012 | 12:22 PM
Stock cubes. Not sure the size of crank pully. All I know is it is a 8 rib with ati crank pully/damper. Exhaust is 1 7/8" longtubes into Texas speed true duals.
Old Feb 2, 2012 | 01:34 PM
conan's Avatar
Need to know what size the crank pully is to choose the head unit pully.
I have a 7.250" crank pully with a 3.7" blower pully making 10-11 #s of boost... 520rwhp, my car was tuned at 5,600 feet/elevation. You should make more power than me if your around sea level.
Old Feb 2, 2012 | 02:42 PM
383camaroz28's Avatar
I made 525 with a 4.38 pulley at 10-12psi
Old Feb 2, 2012 | 06:12 PM
No Juice's Avatar
I have the stock 8-rib kit which comes with the 7.65 crank pulley and 4.5 blower pulley. I see about 10psi.
Old Feb 3, 2012 | 08:19 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
There is no such thing as an 8 or 10 pound pulley, below is why:
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
Hopefully this helps. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Feb 3, 2012 | 08:35 AM
Thanks for the help bob. I will call you when I get the kit and let you know al my specifics and order some stuff. Thanks man
Old Feb 3, 2012 | 08:40 AM
LS1Tech Sponsor
You're welcome, thanks! Bob
__________________
