Another Rear mount build, but it was coming anyway :)
#423
Got it done by an ebay member. Ill PM ya the info for it. he did a good job. I had the flanges welded on by a shop but the header was made and sent to me.
GOT 8 PSI today in the blazing texas heat today!! so its boosting.
I also figured out what that heavy fueling issue was. The old IAT sensor plug kept poping off the sensor. It was old. the "tang" that hold it on the sensor was missing so the vibration kept letting it fall off. so the engine wasn't seeing temps so it was going into safe mode at WOT and over fueling. So a brand new sensor and grommet in and VIOLA!! got full boost at 8psi. Not sure if that my max yet since I was on the street but I got to 8psi before 60mph
So I think I got my boost leak issues fixed. im thinking another fine tune on the dyno and some number are in orders.
#425
#427
No prob, here to help and learn lol
oh and congratz to me for learning how to use the multi quote function lol
#429
I already have an external B&M. forgot what size but its not the largest but its a decent size. it fits in front of the radiator. i do have the trans temp sensor in the diagnostic port so i think the temps there are a tad higher there then in the actual pan, but im seeing 185ish pretty consistently on the temp gauge.
not sure if i should separate the cooler form the factory main, but ive only seen these temps that high in texas. its freakin hot here in el paso right now. we saw 105 today
#432
i wondering if i should go this route.
#433
Try bypassing the radiator before you go out and buy a new trans cooler. You'll be surprised as to how much it will help. I don't even have a helper fan on mine, just passive, and it was better than running it through the rad+cooler.
#434
For Reference:
http://www.tciauto.com/tc/auto-trans-faq
From Answer#1: "This allows the transmission to have its own cooling system and doesn't allow the engine water temperature to heat the fluid."
From Answer#3: "again staying away from the factory radiator cooler lines."
#435
id imagine this is for those of us that are in hotter regions. if you are from a colder region like up north, then keep it hooked up for cold starts. im thinking I might take the stock trans cooler out of the circuit and have the external take over.
#436
so the cars boost 8psi consistently! car feels AMAZING!!! lol
on a none turbo note, got my new driver side power lock mechanism. havnt been able to lock my driver door over the past year and my security indicator has come on e once. Car wonldnt start once :/ need a new key fob too since I broke mine last week. stupid little things. if it isn't one thing its another lol but at least the turbo works now lol now to get the cosmetic stuff taken care of.
#438
on a none turbo note, got my new driver side power lock mechanism. havnt been able to lock my driver door over the past year and my security indicator has come on once. Car wonldnt start once :/ need a new key fob too since I broke mine last week. stupid little things. if it isn't one thing its another lol but at least the turbo works now lol now to get the cosmetic stuff taken care of.
Link... if you've never heard of it. https://ls1tech.com/forums/general-m...how-video.html
#440
The issue is not with the key. The issue is that the design of the wiring from the ignition to the VATS runs in the steering column. The wiring bends every time you turn a corner. For some reason, our cars are prone to wearing that wire out in a certain spot. When that happens, the first sign is Security light (because the resistance is different on the thinner wire... I think). Eventually, the wire breaks from the back and forth bending. When that happens, you have to get towed and either replace the whole ign switch or solder in a resistor and bypass the ign wire to the key. Better to do it now than get stuck and have to do it later. Mine left me stuck after work 3 times before I was made aware of this issue. That was on my first car (2000 V-6). When it happened the first time on this one, I had it taken care of right away.
Another 2 threads that may be helpful to you: https://ls1tech.com/forums/lt1-lt4-m...de-please.html
What resistor do I need?: http://www.vatskey.com/vats/lostvatskey.htm
Glad you've got BOOST! LOL Congratulations!
