Pro charged build..help
Old Feb 2, 2012 | 09:07 PM
Camaro Jearmy's Avatar
Default Pro charged build..help
Using ls1 block, callies h beam rods callies crank, weisco pistons 9 to 1. Looking to make about 700 horse. Need some advice on cylinder heads...cam...intake.... Thanks !
Old Feb 2, 2012 | 09:47 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I'd shoot for a 9.5/1 compression ratio. 700 rwhp can be made with Patriot LQ9 Stage 11 heads (or something similar) with our blower cam and an LS6 intake easy enough with a ProCharger D-1SC. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Feb 3, 2012 | 08:49 AM
What combustion chamber and intake runner
Old Feb 3, 2012 | 08:57 AM
blue00ZZleeper's Avatar
You would need to do it with a compression calculator....static or dynamic? Your combustion chamber size and head gasket thickness will play into it.... Just a standard LS6 intake manifold will do.
Old Feb 3, 2012 | 05:56 PM
how many people are running a gm head with port work?? Is this a good route, or better off to buy an aftermarket set?
Old Feb 3, 2012 | 07:43 PM
I8UR4RD's Avatar
heads with thicker decks are preferred -----AFR 225 or TF 225 have proven well for other builds. if price is an issue stage 3 317's or 243's will work. get a good gasket such as GM MLS or GM LS9 head studs instead of bolts. a good vent setup for the heads. ls6 intake is fine. higher compression is more dangerous. the 9:5 will allow you to roll on pump gas (93) this is also what i am planning to do. many of us actually.
Old Feb 3, 2012 | 08:00 PM
Thanks for the advice..wanting to try to pick up a used set...not having much luck..Might order new ones next week if i don't find any.
Old Feb 5, 2012 | 12:41 AM
I8UR4RD's Avatar
hey man, i have not bought anything used yet, and i have complete and utter confidence in what i am installing. it hurt the wallet, but puts me at peace. its nice to know that you have no chance of being shafted or not knowing what you are getting. i personally will be buying a new rear end heads and everything. the only thing i may get used is suspension parts. lca panhard etc.....
Old Feb 5, 2012 | 06:26 PM
What kind of power are you looking to make? have you ordered a rear end yet?
Old Feb 13, 2012 | 08:57 PM
Head studs worth the extra $120 over bolts?
Old Feb 13, 2012 | 09:01 PM
Head studs are deff worth the $120 bump in price.
Old Feb 13, 2012 | 09:35 PM
Thanks for the quick reply...
Old Feb 17, 2012 | 12:11 PM
fatmat80's Avatar
I am another who is using factory castings on my setup. Stage 2.5 243s from PRC. Ls6 manifold. car works well for me so far. good luck with your build.
Old Feb 17, 2012 | 08:58 PM
I'm using stage 3 LS6 heads and are over 800rwhp with no issues....I don't plan to lean on them to much harder though.
Old Feb 20, 2012 | 08:44 PM
anything over 700 will be great... i think the p1 will make that..?
Old Feb 21, 2012 | 07:42 AM
TermnEatr's Avatar
I'm using untouched 243s besides lapped in valve work and springs and I'm shooting for 700-750 reason I kept stock heads is if I make my goal I won't touch them and saved good money but if I'm just short I know a good head will get me there.
Old Feb 21, 2012 | 08:44 PM
Good point. I got a set of cnc'd 243s so I sure hope to hit the 700+ goal.
