Charge Temp Bias / HPtuners
Why would you completely disable something that predicts fueling needs based on temperature? It would be like running a carburetor with a disabled bias table and open loop tune. Instead of disabling it try experimenting with it to compensate for your fuel swings. This is assuming you're running a 01+ operating system, as everyone with the ability to should.
![Red face](https://ls1tech.com/forums/images/icons/icon11.gif)
There is a Bias and Filter option. If disabled the charge temp values will be soley from IAT, if on it will use a variance between ECT and IAT. Higher numbers in the Bias section will lean towards ECT. Wondering what you guys are doing that are running Turbo applications and you have relocated the IAT sensor. Are you having large fuel swings when on OPEN LOOP?
Many are having to teak tunes that are in open loop when temp swings high or low vs the time when they originally tuned their car. Curious how the members on this board where dealing with this issues.
Reckon not many are tuning their own cars on here.
Theirs been a lot debate on how to remedy this on the hptuner forum.
The original IAT location is in the MAF sensor in the OE application for a specific reason. If you change the location of the IAT sensor to more accurately read IAT's before combustion (such as with a roots type supercharger) then the original intent and purpose of this "modeling" no longer applies. I believe you should only disable this if you have an intake mounted roots/screw type supercharger since the IAT sensor is relocated directly into the the lower intake.
To answer your question, the temp does not "swing" in the manner that you are thinking (for me anyhow), even when changing to a thermistor with a faster refresh rate. My IAT's climb and fall gradually when getting into boost, but nothing like you are thinking. My car runs great no matter what the ambient temps are...if that is what you are truly asking.
I think you guys are putting too much thought into what this function actually does. IAT still has every bit of impact in fuel and timing even with this specific feature disabled.
