Stock Long/Short block record contender
You all are friggin rediculous! If its got stock crank, rods, and pistons.. its a stock bottome end. I mean who cares about the rest... the ring lands are the weak link anyways.
I can believe you guys are all pissy about what is or isn't stock in the engine, yet YOU CHANGED THE ENTIRE CAR THE ENGINE CAME FROM. Lol. its the stock bottom end record... not stock-bottom-end-that-gm-assembled record.
Good luck buddy... rod bolts, rings, and whatever.. regardless.. skinnies went friggin quick... and it will be tricky to run him down weather you change those things or not
