Stock Long/Short block record contender
Not sure if this is true, but someone told me sbf headers will fit on ls1s if you obviously cut off and weld on new flanges, as in the tubes line up perfectly with the ports. True???? May be something to look into
Get the raceweight around 2900-3000 pounds with driver and you'll have a good shot.
I'd go ahead and go with 120 or 160lb injectors and a magnafuel fuel pump.
Also I have a question for the jerk-offs, what can I do about the rust from the knock sensors that fell into the valley, cleaning it out without disassembling the motor to clean it and keep it stock short block?
Also, is the cam/ internal cam bearings considered short or long block? I mean it's in the bottom end but contributes to the top end.
I said a single plane lol. Super Victor would be great, and go ahead and get the 4500 tb now with the EV carb hat. Plate? Spacer you mean? Or nitrous?
T6 borg unit is a great choice.
Look at the S88. It's the same popular 96mm hotside with a 88mm compressor in the S400 chassis so it's not hugeish like the the S500 chassis turbo's.
Edelbrock pro flo xt
And yes i was thinking of stashing a nitrous plate under the 4150 tb if i decide to go single plane.
Intercooler?
Acceptable IAT temps for E85/C16?
