LQ4 S480 Build
Old Nov 5, 2013 | 10:37 AM
  #1081
831jd's Avatar
Are you just running a 2 step no transbrake? Is it the abs delete kit that allows you to hold the car better?
Old Nov 6, 2013 | 07:22 AM
  #1082
F110Mech's Avatar
Doug, if you end up coming down to atco you can crash at my place so that you're not making that drive twice in a day and dont have to pay for a hotel/keep your car in a parking lot
Old Nov 6, 2013 | 08:19 AM
  #1083
Camaro9969's Avatar
Yes i have a transbrake. Yes the abs delete kit but i do not use the line lock to hold it during the launch.
I've got the brake and the pulse leash which i havent even gotten to use yet
Thanks man its not too bad of a drive we went to atco after i picked the trans/rear end up from you after that even went to englishtown. I saw black friday is an all day event so should get a lot of passes in.
Old Nov 6, 2013 | 04:53 PM
  #1084
Camarolsx69kk's Avatar
Just finished reading this whole thread!! This has so much great information. Thanks for sharing your set up/built with us Doug! I am working on a turbo ls1 build myself. This motivates me to buy more parts that I need!! Just wondering what type of rockers do you run with the 317 heads?
Thanks again
Old Nov 6, 2013 | 05:02 PM
  #1085
Camaro9969's Avatar
Thanks again
Your welcome glad you like it!!! I just run stock rockers. Only thing done to the heads are chromoly pushrods and lunati springs
Old Nov 6, 2013 | 05:03 PM
  #1086
Camaro9969's Avatar
Here's my YANK flexplate destroyed and cracked in the middle.......
Old Nov 6, 2013 | 07:40 PM
  #1087
DEFYANT's Avatar
Oh wow.... Sucks man! Sorry to see!
Old Nov 6, 2013 | 09:01 PM
  #1088
Camaro9969's Avatar
Its what happens when its restamped Chinese junk. This tci I bought its so much thicker its shocking the difference in quality
Old Nov 6, 2013 | 09:08 PM
  #1089
sbcgenII's Avatar
Thats some BS thanks for the heads up.
Old Nov 7, 2013 | 07:09 AM
  #1090
Camaro9969's Avatar
I agree. Heres the one off ebay i wont list who but this is only 60 bucks.......
I would go with a TCI at min or the badass circle D billet one they sell
Old Nov 7, 2013 | 07:19 AM
  #1091
RedRocketZ28's Avatar
Damnit, I have a Hughes and it looks identical to the pics. Oh well I suppose, we will see how it likes the winter upgrades this spring!
Old Nov 8, 2013 | 05:59 AM
  #1092
Camaro9969's Avatar
Got the new plate in took it for a drive and it wouldnt build more than 8psi and the car had no torque like it had before even under half throttle, and when i would come to a stop it would hang high idle like a vacuum leak. Other than the no boost and high idle car is running great. So yesterday did a compression test, that was great, did a leakdown and that was the same on all cylinders and numbers were fine. So pulled the head off and no bent valves i'm thinking Lifters? Broken inside Spring?
Either way i'm going to upgrade everything (Pushrods, Springs, Lifters and possibly Rockers) since it needs it anyways but it will suck if i do all that and its got the same problem..........
Old Nov 8, 2013 | 09:03 AM
  #1093
Sales@Tick's Avatar
I know this might sound stupid, but if something with the flex plate and converter were binding or not allowing the converter to spin inside the pump like it should it might cause what you're describing.
Old Nov 8, 2013 | 09:13 AM
  #1094
Camaro9969's Avatar
I'll take any advice at this point.....
Ya i have read about that. This flexplate bolted up way nicer than the YANK one did. You think it would cause idle hang also? And a massive torque loss. I made sure the correct spacing was there also.
Old Nov 8, 2013 | 09:21 AM
  #1095
Sales@Tick's Avatar
Just an idea. Seeing as it's the ONLY thing that changed...
Old Nov 8, 2013 | 09:33 AM
  #1096
Camaro9969's Avatar
I agree but it did take a nice little zing to it. 20psi 5500 then the plate broke buzzing it up to 7780 instantly so something could have happened. I wont find out for a while now as the heads are off and i'm going to upgrade the valvetrain while they are off. Maybe i have some broken springs that i'll check today.
Old Nov 8, 2013 | 03:36 PM
  #1097
mrstepheneades's Avatar
Dang I feel for you Doug. Like a dark cloud is over your car and wont leave.
Old Nov 8, 2013 | 04:42 PM
  #1098
Camaro9969's Avatar
Ya its rough but when you push stock parts to about 1000 crank time and time again its hard to keep it together eventually ill weed out the stock crap and take this seriously. Its definitely not been an easy road
Old Nov 8, 2013 | 06:52 PM
  #1099
MUSTANGBRKR02's Avatar
Time for upgrades!
I was going to mention the converter as a possibility.
Old Nov 12, 2013 | 11:13 AM
  #1100
Camaro9969's Avatar
Originally Posted by MUSTANGBRKR02
Time for upgrades!
Yup PAC Springs BTR lifters pushrods and trunion upgrade. I'll just delete things one by one what it is and this stuff should be upgraded at this point anyways.
