LQ4 S480 Build
Old Jun 10, 2014 | 09:56 PM
  #1281
Sales@Tick's Avatar
Sounds like the scales are way off.
Time to put it on a diet. Mine is sitting at 3175 with no lead in it and me in it. I still have power windows, power door locks, door bars, all factory glass and every single piece of plastic interior paneling in the car other than the center console. No mini tubs and I still have factory upper/lower control arms and spindles. Oh yea, and the factory gas tank too lol.
Motivation for ya.
Old Jun 11, 2014 | 02:42 AM
  #1282
MUSTANGBRKR02's Avatar
Motivation for ya.
I need to load my car up when I get back and come see you one weekend then. I have got to be close to 4k in my Vert with me in it. I will strip mine to just about nothing lol.
Old Jun 11, 2014 | 06:02 AM
  #1283
Camaro9969's Avatar
Motivation for ya.
3175 with you in it and a 25pt? What do you have taken out that is making up such a large weight difference?? Maybe the scales are off but they aren't off much
I could take out 100 with just interior removal and half tank of gas after that it's going to get expensive
Old Jun 11, 2014 | 06:47 AM
  #1284
Ryans99ls1's Avatar
Originally Posted by Camaro9969
3175 with you in it and a 25pt? What the hell is taken out? What do you have taken out that is making up such a large weight difference?? Maybe the scales are off but they aren't off much
The front half of his car is missing lol. I would love to get mine around a 3400lb raceweight, im at 3615 now. How much does the HVAC stuff weigh?
Old Aug 18, 2014 | 07:24 AM
  #1285
Camaro9969's Avatar
So I haven't updated this in a while have been dealing with issues all year. After about 250 miles on the new motor i noticed the oil pressure gauge bouncing at idle but under wot was great had 70+ oil pressure. Then after taking it for a test ride before the track got home and it idled around 20 and knew i didnt have much left. Took it to the track the next day mid pass looked at the gauge and had about 25psi WOT so threw it back on the trailer. Yanked the motor out to see the mains destroyed. Brought it back to the shop that built it and after 3 weeks they told me the crank was bent and cracked....The Crank in the motor was actually from the motor that made about 1050ish hp so in my opinion the crank was never checked before it actually went into this motor and was already on its way out. But either way just waiting for a couple fittings and my turbo to be sent back and i'll go at it again! This time around i got a fuel cell in the stock location, Holley Dominator 12-1800 pump -10 Line for e85 -8 return Y Feeding the rails and changed my seats from the Corbeaus (37lbs each) To the Kirkey's being 11lbs each so a total i've taken out about 175lbs so far.
Here are some pictures of the mains lol
This is about 1/2 of the flakes i found in the bottom of the pan.
Motor #5
At least we found some use for my bent crank and rods
Soon as the Turbo comes back i'll be at the track again and hoping to make the YB Nats next week
Old Aug 18, 2014 | 07:31 AM
  #1286
mrstepheneades's Avatar
I like the dog. That's pretty cool using old parts for something lol. I hope to get mine down around 3200 range as well. I took my hvac stuff and airbag/bracket out of the dash this weekend when I reinstalled and that stuff had to weigh 40lbs. Especially the airbag stuff. I weighed my car before with all stock stuff plus the turbo stock on old setup and was only 3400 with a half tank and 3 gal of methanol w/o me in it. I know with auto trans fluid, cage, blah blah its gonna be hard to get back below that especially with twins and iron block.
Old Aug 18, 2014 | 07:35 AM
  #1287
F110Mech's Avatar
Always happy to see updates on this Doug. Definitely won't have fuel issues now haha
Old Aug 18, 2014 | 08:39 AM
  #1288
Excited to see this thing on kill!
Old Aug 18, 2014 | 10:01 AM
  #1289
Mike454SS's Avatar
Looking good Doug...your mains are supposed to look like that...less friction on the crank!!!
  #1290
White.Lightning's Avatar
Also got my turbo back again with a new PTC 9.5" converter. And got the trans refreshed
Still running the Transmission Specialties RMVB TH400? Their shop is located 5 mins from my house. Do you have a JW Ultra Bell on it?
Hopefully you make it there. I'd love to see the car in person. I'll be spectating and snapping photos.
Old Aug 18, 2014 | 04:43 PM
  #1291
Camaro9969's Avatar
I think I'll be at 3300 and 3500 with me which is fine for now and should help the parts from getting their asses kicked as bad
I sure hope not!!
Well besides I need 100lb+ injectors
You and me both just not sure where on kill is stock was 1200hp forged guess it was 800 haha I have high hopes for this set up though
Lol
Yes I am. It's been a badass transmission and taken such a beating. No JW bell
I'm trying like hell to make it but it's not easy just got a call saying my center section on the turbo is shot again! Def surprised me I get it the mains were destroyed but it lasted maybe 50 miles and 5 dyno pulls
Old Aug 18, 2014 | 05:56 PM
  #1292
oakley6575's Avatar
Wow that dog is badass. Probably my favorite part of this build. . . Obviously kidding.
This car is badass and can't wait to see it back at the track. What crank did you use this time around?
Old Aug 18, 2014 | 06:23 PM
  #1293
Yes I am. It's been a badass transmission and taken such a beating. No JW bell.
Sucks about the turbo. Good luck getting it back together.
I thought you had to run a JW Bell or an SFI blanket/shield on the transmission?
Old Aug 18, 2014 | 07:06 PM
  #1294
Camaro9969's Avatar
Haha guard dog!!
Unfortunately stock I was told it had oiling problems then he actually took it apart and put it back together before I had a chance to say I wanted a forged crank. He told me it was bent and cracked after he put it together......
Old Aug 18, 2014 | 07:09 PM
  #1295
Camaro9969's Avatar
No just blanket and shield
Old Aug 22, 2014 | 07:04 AM
  #1296
Camaro9969's Avatar
Back up and running. Will take it out for a drive today do a couple pulls and hopefully hit the track tonight and tomorrow.
Sorry for the video being sideways...........
Old Aug 22, 2014 | 07:15 AM
  #1297
Good deal. Don't push it at the track! I expect to see you at Cecil.
Old Aug 22, 2014 | 07:26 AM
  #1298
Camaro9969's Avatar
No meth straight C16 this time until i get some real injectors.......But i'll run some 1/8th mile until i see the numbers where i want then go to 20psi i haven't even been above 17 all year so i'd say its about time!
Old Aug 24, 2014 | 06:02 AM
  #1299
Camaro9969's Avatar
So worked on the car all night to get it tested at the track before the YB Nats next week never had a chance to even drive the car before the track first pass just low boost then checked everything out and kept turning it up overall day went well and will try to get a couple more passes in before we head to MD.
My Buddy Shawn's Toyota Crown
16.8psi
19.1psi
Old Aug 24, 2014 | 06:44 AM
  #1300
35thsscamaro02's Avatar
Nice! How much boost on the last pass?
