oil restrictor
Old Feb 19, 2012 | 10:23 PM
97_C5's Avatar
Default oil restrictor
Got a b&w s480 do i need to run a oil restrictor in the oil feed line and if so are there different sizes?
Old Feb 19, 2012 | 11:06 PM
Texhotrod593's Avatar
Is it a journal or ball bearing turbo?
Old Feb 19, 2012 | 11:41 PM
97_C5's Avatar
Journal, sorry should have listed that.
Old Feb 19, 2012 | 11:42 PM
silver_82's Avatar
it has its own restrictor built inside the bearing housing i believe.
Old Feb 19, 2012 | 11:45 PM
97_C5's Avatar
Looks just to be a threaded port doesn't look like any restrictor in there.
Old Feb 20, 2012 | 01:05 AM
silver_82's Avatar
I had an s480 and was told that the bearing had its own "built in" restrictor. Explained to me this way, these turbos are built for diesels and if you look at the feed lines there are no restrictions.
Make sure you have an adequate return (size and routing) and a well vented crankcase and it shouldnt smoke. Plenty of oil will help cool the bearing housing and prevent oil from baking/burning inside
Old Feb 20, 2012 | 07:49 AM
Exactly, just run a 1/8" feed line to it and about a 1/2" return and you should be golden
Old Feb 20, 2012 | 07:53 AM
I dont think journal type have any type of restrictor. Think of the bearing being similar to a crank bearing. You have a "pressure" build up to basically "float" the shaft. A ball type needs to be restricted on amount of oil supplied
Old Feb 20, 2012 | 02:02 PM
97_C5's Avatar
Appreciate the info, and the plan was to run -8 or -10 for a return line either to the timing cover, or oil pan.
Old Feb 20, 2012 | 02:08 PM
Go -10 you won't regret it
